Page 3 of 8
Posted: Fri Apr 02, 2004 2:12 am
by powerfulalien
Thanks thawa i will send them after i have it put back together
Posted: Fri Apr 02, 2004 9:05 am
by eastbaysubaru
More pics is always a good thing. Good work Thawa!
-Brian
Posted: Fri Apr 02, 2004 3:43 pm
by THAWA
im not doing anything
thank powerful.
Posted: Sat Apr 03, 2004 4:40 am
by powerfulalien
well i have the pics... unfortunately i work tonight . thawa where do you want me to send the pics to ? It will be sometime tomorrow afternoon at the earliest ( I work graveyard ) I think I took about 40 pics !!!
thanks
Posted: Sat Apr 03, 2004 5:01 am
by THAWA
my email addy, awesome amount of pictures
Posted: Mon Apr 05, 2004 3:56 am
by powerfulalien
thawa your email address comes up bad service module
[/b]
Posted: Mon Apr 05, 2004 3:59 am
by THAWA
well your e-mail address smells like poopy!
naa jk, You can try mailing them to
webmaster@thawa.net
Posted: Mon Apr 05, 2004 4:38 am
by powerfulalien
that one doesnt work either damn comp
Posted: Mon Apr 05, 2004 4:42 am
by THAWA
try creating an account and uploading them here:
http://thawa.net/images/
Posted: Mon Apr 05, 2004 4:56 am
by THAWA
incase you were trying to upload and couldnt i had the settings wrong, so you can now upload so long as youre logged in.
Posted: Sun Apr 11, 2004 9:24 am
by THAWA
any updates on this?
Posted: Thu May 06, 2004 2:47 am
by Sub4evr
well I to have a leaky sunroof, what i've discovered is the seal around the glass is torn. what i've been told is you have to buy the glass as one piece you can't just buy the rubber and redo it. does anyone know if this is true if so I guess I have to buy a used sunroof from the wreckers?
Posted: Thu May 06, 2004 5:01 am
by eastbaysubaru
You cannot replace the rubber part of the glass AFAIK. The other problem is that most of the ones you'll find at the JY's are torn as well
My glass was cracked so I picked one up at the JY and the rubber was a little torn on that one as well.
The rubber isn't meant to completely seal the moonrood either. You've probably got some of the same problems that the rest of us have.
The main problem is that the sealing caulk that was originally installed to seal the sun/moonroof tray to the actual roof panel is old, dry and cracked This then acts like a sponge and dumps it either in your lap or your passengers
The other is that your drainage tubes that drain the tray are clogged up.
The "real" way to fix it is to remove the headliner completely and lower the sun/moonroof tray, reseal it, and reinstall the entire thing. Someone did just this on the board and it fixed all of their leakage problems.
-Brian
Posted: Thu May 06, 2004 1:07 pm
by Sub4evr
I hear ya, it's just that I've gone through the whole thing and my sunroof was still leaking. I got the rails resealed and the 4 drainage tubes are working just fine. the problem I'm having is, after a very heavy downfall I drive down the street use the brakes at the first stop sign and i have a water fall on the passenger side. a light rain won't do it, it seems there is a lot of water stored up in the tray and when I brake it all rushes forward and the drain tubes can't handle it and it spills into the car. so i'm still trying to find a solution
Posted: Thu May 06, 2004 4:10 pm
by LaureltheQueen
mine doesnt leak.
Posted: Thu May 06, 2004 4:17 pm
by NuwanD
you may have missed a spot when resealing the sunroof, when doing mine i noticed a few locations which don't have much height and thus won't prevent a large amount of water from getting past... i used silicone to make a "wall" to make theses spots higher
Posted: Thu May 06, 2004 4:48 pm
by eastbaysubaru
What ^he said. I'm going to have to redo mine because I didn't make the silicone high enough in certain spots
When I eventually get around to it though, I'm pulling then entire headliner.
The other problem that I noticed is that the original sealant goes much further towards the back than I could get without removing the headliner. So I just caulked up as much as I could. It obviously didn't work because my wife keeps getting water dumped on her lap
-Brian
Posted: Fri May 07, 2004 5:11 am
by evolutionmovement
My cheap ass pop-out the insurance company half paid for when my windshield was done never leaks.
Posted: Thu Oct 21, 2004 5:51 am
by azn2nr
time for me to jump in. last year it didnt leak but now it does. i dont think its the seal but i do think its the drains. when my inner fenderliners tore out the drains were exposed to open air.
could this possibly be the problem? im gonna try to get some air to shoot in it but i doubt keyboard cleaner is gonna work. i may need to go get an attachment for my compressor
Posted: Thu Nov 25, 2004 4:59 am
by biggreen96
fixed my sun roof!
I pulled the trim, headliner and removed the whole assembly. took it inside and scraped the old stuff out- it was cracked out big time. vaccumed the loose bits away and laid down new sealant. Only took 1 hour with a friend ( let it set for and hour before i put it back in) having a friend is definatly recommended!
Posted: Sun Dec 12, 2004 5:44 am
by eastbaysubaru
Today was the day I tackled the leaky sunroof the right way. Pulled all the trim pieces and the headliner. What a royal PITA!!! Cracked a few trim pieces and broke a few clips. I'm really excited to finally have the sunroof not leak though. My wife will be happy when she doesn't get rained on in the passenger seat
The drain tubes themselves are pretty sizeable, so I think it'd be tough to clog those like some people have suggested.
Tomorrow I'll be pulling the sunroof out to reseal it and get it winter ready. It's definitely a two man job though. Very hard to get the headliner out of the car by yourself. I'm also considering having the headliner recovered while it's out. Has anyone ever had this done? If so, what was the cost?
I'll take a bunch of pics tomorrow of all of the trim pieces so we have a reference for removing it all. Hopefully having some pictures of the trim pieces will prevent people from breaking/cracking them.
-Brian
sunroof/moonroof problem - pictures?
Posted: Mon Dec 27, 2004 7:30 pm
by 1993 Legacy
Hi Brian and all,
Has anyone posted any photos of the sunroof/moonroof repair procedure somewhere. As it happens, winter came and my Legacy station wagon started leaking. Today. Right onto my left shoulder. It never did this before. I would really appreciate pictures of the procedure as on speak a thousand words, no? Please let me know.
Thanks in advance.
Best regards
Dusan
Posted: Mon Dec 27, 2004 8:59 pm
by snowboarded
I had the same problem that you have Dusan. Mine no longer leaks tho. It was a quick, cheap, and easy fix for me.
Here's what it takes. Buy one roll of electrical tape.
Tear off long pieces and apply to edges where the moonroof and roof meet. And violla! No more leaks. If you do a good job nobody will notice that the top of your car has electrical tape on it.
Works good as new, if you never open it.
Posted: Mon Jan 03, 2005 7:53 pm
by eastbaysubaru
I currently have the entire headliner removed in a friend's garage. I'm going to reseal the sunroof and reinstall it tonight. I'll try to take as many pictures as I can and post them here. The problem is all the plastic is extremely brittle and is hard to remove without cracking it
-Brian
Leaky sunroof fixed
Posted: Tue Jan 18, 2005 3:16 pm
by 1993 Legacy
Hello to all,
Just an update. I fixed the sunroof/moonroof leak. The info on the site has been helpfull. After taking the whole headliner down and pulling the whole sunroof/moonroof assembly out of the car the problem with the seal was evident. It took less than an hour to disassemble the lot and bring it into the house. I must admit that my gf didn't quite appreciate the mess that ensued. Besides it was all happening on the floor of her living room. I couldn't fix the car in front of my house so her place was the next best choice.
)) anyhow, after letting the sealant cure overnight I put everything back together and it hasn't let a drop of water in since then. I would suggest the procedure to anyone with this problem. It solves it for the next 10 years. At least. I used gasket sealant first and silicone calk (sealant) later along the sides of the rails both on the inside and the outside of the rails.
Just a bit of advice. Be gentle with the interior trim as it can be brittle and brake easily. It is all attached with clips so it is simply pulled out.
Best regards
Dusan
