My turbo died tonight
No, I'm sorry but you are wrong.
Header wrap is made for a reason. Turbo's are wrapped for a reason. The faster exhaust flows through the turbo, the better.
You want the headers, crosspipe, and uppipe to retain as much heat as possible, to help spool time.
so then heat isn't bad for it now is it?legacycontinues wrote:I know my car runs like shit when it is cold....(cold for FL is like 60)
Notice, also, you must wait for the car to WARM UP before driving hard.
You don't get peak performance on cold parts.
I mean, shit, look at the SR71. That thing leaks fuel and shit like a mofo at the surface, but once it's 85,000 feet above the surface, it's tighter than Britney.
legacycontinues
- Voluntarily Dismissed
you kinda just contradicted yourself there, because britney is not tight.
Yeah too much heat is bad for anything, and not enough heat is just as bad. Go start a computer in -60 degree weather.
legacycontinues
I said weather not cpu temp. And last I checked there weren't many people that had cpu temps that low. Lowest I had heard was like -20 and that was using liquid nitrogen
So your saying that engines perform their best as soon as they are started?legacycontinues wrote:too much heat is bad for anything. I work on computers....I have seen melted intels.
You said yourself, that your car runs shitty on a "cold" start.
legacycontinues
was it -60 degrees? It couldn't have been, because you said it was a frige.
legacycontinues
I have never gotten a computer that cold. I wouldn't put myself out in that hell let alone a computer.....well maybe a gateway or acer....just to see what would happen.
Off subject: I took apart an old compaq the other day and it had a subwoofer in it. I now use it on a 13" tv I have in my garage....that thing actually makes god bass. Doesn't rattle the windows or anything but it is interesting. I hear those Bose wave radios pound pretty good too.
Last edited by legacycontinues on Thu Mar 10, 2005 8:30 am, edited 1 time in total.
legacycontinues
We wouldn't, because it wouldn't be to smart. Just like putting a turbo under the gas tank.
i totally suggested that to phil
It would increase fuel pressure right?
HOLY SHIT! Hardy called that one! WOAH, I'm freakin out!
Gives a whole new meaning to the Turbo Pump.
legacycontinues
legacycontinues
legacycontinues
OR, you could stuff the twin turbos on your JDM TT under the gas tank, and compare drivability to my car.
I'd be willing to bet, that my car wins.
legacycontinues
I don't mess with what works (and is cheap) the TT's are staying where they are.....and I'll smmmooookkkkeeeeee ya!
I'm going to race everyone around here!! Just to see the look on their face when they get toasted by a wagon.
Last edited by legacycontinues on Thu Mar 10, 2005 8:49 am, edited 1 time in total.
