CarPC installation
The final necessary component is on it's way
In other news, I've finally settled on a place for the motherboard and harddrive. They're going to go into the empty cavity in the dash behind the LCD screen.
I'm going to have to do some escher-esque arrangements to get it all to fit and still be accessible for plugging things in, taking out the HD etc, but it seems like it should all fit.
Epia V 800mhz Mobo/Processorwiscon_mark wrote:very nice fabwork, what're the specs on the computer?
128mb PC133
120W Opus DC-DC PSU
7" Lilliput LCD
Windows XP is running, stripped down to bare essentials, with Centrafuse 2.0b running as the shell (touchscreen interface designed for CarPC use)
- Title Whore
- Title Whore
I've never gotten a BSOD while using XP. If you have, I'd blame your hardware.0perose wrote:hehehe... your car is running windowsxp... I don't think I'd like to have to reboot (or deal with bluescreen) while driving down the road
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Eh, havent had a single crash yet.0perose wrote:hehehe... your car is running windowsxp... I don't think I'd like to have to reboot (or deal with bluescreen) while driving down the road
It's barely running XP. It's stripped down to bare essentials, and using Centrafuse as the shell instead of explorer.
I need XP because Linux is pretty flakey with the Epia processors, not to mention all the other freaky-deaky hardware that's in this thing. Also for the hibernation ability, and the fact that almost all the touchscreen interfaces are designed for windows
Windows, as a simple system is not bad at all, its when you add this, that, and every little feature, program, etc, that it gets buggy. He should do fine with the barebones version, as long as his programs that he uses are well-written...
185,000 miles
185,000 miles
That's awesome. I took my stereo out recently to clean it and realized that an LCD would fit in the space quite nicely.
Here's a sweet carPC in an evo, if you haven't seen it:
http://home.nc.rr.com/smanders/evo/carpc.html
Check these out on ebay...uber cheap and they will save a ton of work if you are considering installing a PC in your vehicle. I believe they have USB built in as well.
http://cgi.ebay.com/8-TFT-LCD-VGA-Touch ... dZViewItem
http://cgi.ebay.com/TM-868-8-USB-Touch- ... dZViewItem
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
Alright I've begun what may end up being the final casing. Using the same roofing foam I got to make my speaker gaskets, I've just been layering it, with holes cut to fit the components
It should keep the harddrive fairly free from vibration, while allowing lots of surface area for cooling.
How are you turning that thing on? Are you setting off the jumpers or do you have an actual switch made?
