Yes, pretty certain. There is an operation chart in the ATSG manual that explains it. Lock-up is most noticeable in D4.vrg3 wrote:Thanks for chiming in, Joe. Are you certain that the torque converter doesn't lock up when the TCU is in power mode? The reason I ask is that, from my understanding of the torque converter lockup control mechanism, it seems that the converter is always locked up in 2nd, 3rd, and 4th gear, no matter what. I believe the hydraulic circuits in the transmission are designed so that, in those gears, there is no oil pressure supplied to the lockup clutch.
Lock-up does not work in R,N or 1. It does not work below 40 degrees C, during shifting, at WOT or under rapid acceleration.
For steady driving it will lock in 2, 3 or 4, but only in Normal range.
The software makes the assumption that if Power map is activated, the driver wants all available torque for acceleration, and the TCU commands the lock-up release circuit open, duty ratio 5%.
This is backed up by what we have found in practise; the gearbox will not lock once Power mode is on.
Joe
