Out with the 92: In with the 94 Legacy Ti
92wagon
Re: Out with the 92: In with the 94 (update 03/21/12)
Post by 92wagon »
How it sits today! 3/21/12
I'll try to get some better shots soon.
Playing in the mud is always fun :)
92wagon
Post by 92wagon »
I replaced the passenger side fender this past weekend. The one I took off is going in for surface rust repair..
Also test fit flaps today.
I like the look. :!: :!:
I'm going to install them tomorrow! :mrgreen:
92wagon
Re: Out with the 92: In with the 94 Legacy Ti
Post by 92wagon »
I replaced my front seats with RS fronts this past weekend! Had them in the 92 as well. Now onto the 94 :)
they need a bit of cleaning....but other then that they are in good shape.
also got the flaps actually installed last weekend
concretelegacy
Post by concretelegacy »
:D Nice Ti!
I gotta ask, was the air suspension tits up? Or did you just want the reliability of normal struts?
-Brian
2002 Forester
2009 WRX
92wagon
Post by 92wagon »
^ Sorry it took so long for a reply!!! The air suspension was complete crap... and yest the reliability of the normal strut/spring was a definite plus...
I've got some new tires for the LGT rims! should have them on next week
and found a neat little hide out in the local woods so I figured I'd snap a couple pictures while there.
92wagon
Post by 92wagon »
Now Clean with re-sprayed wiper arms and steelies.
.......and now for some night shots! I'm such a pic whore.
92wagon
Post by 92wagon »
Changed the steelie color from primer grey to flat white. I like it better.
keithmoilanen
Post by keithmoilanen »
Looks good how did u attach the flaps
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
92wagon
Post by 92wagon »
Thank you. :)
I used speed clips and screws.... I used nuts and bolts on my wife's red LGT in front of mine
keithmoilanen
Where did u get the flaps
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
92wagon
Post by 92wagon »
I got them from Ballistic Motorsports. http://www.mainelysubarus.com/forums/to ... ne-gaurds/.. I had to call them to order. They have a variety of different colors are hard plastic and rugged as hell
keithmoilanen
Can I get the number
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
92wagon
Post by 92wagon »
92wagon
Post by 92wagon »
So I keep having issues with my throttle sticking a bit... about fifteen to seventeen hundred rpms... I've noticed that when it is sticking (the plate and screw in picture) aren't touching ... So I've PB Blasted the shit out of all the springs and it still sticks... where can I go from here??
92wagon
Post by 92wagon »
I adjusted the throttle cable just a bit and it seems to be better.. we'll have to wait and see..
92wagon
Post by 92wagon »
also yesterday I cleaned out the throttle body.. It wasn't all that dirty. hopefully these couple of things will keep it from sticking.
Can you get new springs for the throttle body?
Not really. It'd be easier just to pick up a used throttle body.
92wagon
Post by 92wagon »
I actually have a used one from my old engine. I should just transfer it over eh.. see where that gets me.
Why not remove the throttle body and take the springs off and wire wheel them really good, get all the rust and corrosion off and clean the throttle body and TPS and stuff and lube it up with some lithium grease and reassemble? Make sure it spins easily by hand after it's all cleaned up before you put it back on.
92wagon
Post by 92wagon »
^^ good point.....
On another note....
I got eight pieces of aluminum. each 23.5 long and 15.5 wide. I need to fabricate skid plates NOW!
Does anyone have any info/specs of their own skid plate that I could use as a template???
Danny-G
Post by Danny-G »
I would measure mine but it recently got killed while I was wheeling. I may still be able to measure it a bit though.
Danny
92wagon
Post by 92wagon »
sweet. I'm on another forum (Mainely Subarus) and someone posted this up but it's for a GD impreza. So I'm not sure how close it is.
92wagon
Post by 92wagon »
Got a bit of bodywork done on the Legacy today. Managed to dodge the rain clouds as well.
The color match doesn't quite match up but ah well....Sorry for the HUGE pictures..
92wagon
Post by 92wagon »
Well the roof of the legacy got some much needed love yesterday! Scraped/Sanded/Primed/Plasti-Dip.
