Post your FMIC's!
Re: Post your FMIC's!
I love me a FMIC! I just wish my little turbo could use one... Lets see some pics of the huge a$$ turbos pushing air through those beasts.
93 T-leg, td-04, mbc, tmic, fcd, tbe "J. Hooper-T"
03 WRX, staged.
03 WRX, staged.
here you go, GT3076R
*sold*
*sold*
gt3076 and 6 total feet of intercooler piping
^^^ Man, that's hot. I wish I had the resources (money for new parts, welding / fabrication equipment) to go with a reverse manifold FMIC setup. Your car looks like it's got a lot of nice parts. Do you have a build journal?
back door intercooler ftw.
Jake did you rewire your car to run the avcs heads? im on the fence whether or not to go with the 257 heads on the 257 block im building.... my hydra will run them
*sold*
*sold*
thanksDominator wrote:^^^ Man, that's hot. I wish I had the resources (money for new parts, welding / fabrication equipment) to go with a reverse manifold FMIC setup. Your car looks like it's got a lot of nice parts. Do you have a build journal?
MikeyMeyagi wrote:back door intercooler ftw.
yes indeed, its running off of a 2004 STi ecu with an accessport. the downside to avcs heads is cams are more expensive which is why i went with stock STi cams.
nice man.... i think ill try the 25d heads and see what happens. if doesnt work out and make the power i want, ill step up to the avcs heads and run the wires needed to the hydra. You have a built block in that thing?
*sold*
*sold*
Yup, cp pistons and eagle rods. Got tuned today and made 377 whp @20psi
On a Sunday?! What, do you have your own dyno or something?jake15 wrote:Yup, cp pistons and eagle rods. Got tuned today and made 377 whp @20psi
Sweet setup, Jake.
Hey Mikey, i've been meaning to ask you, with the 25d heads on the stock block before garret turbo and standalone, how was the off boost power with the lower compression? I've had a set of 25d heads sitting around for awhile now but haven't put them on cuz i fear that low compression. I was waiting for winter to tear it apart and was gonna rebuild the block with the higher comp wisecos but really don't want to spend all that money on rebuilding it. My goal for my wagon is not crazy power, don't have the money with a family to support but i do like some fun. My goal is 25d heads, td05, 550s, robtune or maybe adaptronics and some other bolt ons. A big part of not going crazy is the tranny options, the only reliable options are sti swap or straight cuts to handle more power and both are too much for me.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
do a w58 swap. but then ur rwd. less then 1000 dollars
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
I've actually considered going rwd and it is still definately a possibility. I could probably get the w58 super cheap too since i work at a salvage yard. Is anyone making and selling the adapter plate yet?
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
That would be an cool project. Start a new thread about it. I'm definitely interested in learning more.
yes i have one. type in rwd in search and there is a thread saying something about finally a rwd option in the works. i havent bookmarked it yet. i bought one from the guy,bill. hes a pretty cool guy and will work with you. mine was 450 or so shipped. i dont remember.
Finally got around to reading the huge thread Bill had on the bellhousing project he did. Since, you actually installed it though, other than swapping bellhousings what else has to be done? Anything have to be done with the driveline to match up and what about shifter linkage? I found a w58 today at work, 50 bucks. I may grab it but wanted to see what else i would need to do first.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
I am going to ressurect this thread to add in how I installed my FMIC. The video I posted didn't work, so here are some pictures off my website.
Last edited by beaconhillkilla on Sat Sep 15, 2012 11:23 am, edited 1 time in total.
1992 Legacy SS - Auto to 5MT swap and too much of my free time.
Video no worky.
Just added some pictures
Nice fabwork on the FMIC!!
Thanks! My biggest issue was that I didn't want to have to relocate the battery to the trunk, that wire is expensive!! I went through four cutting disks on my angle grinder and 3 sawzall blades for the whole thing haha.
