macipusy wrote:Maciek’s 1991 2.35L Turbo Legacy (updated 7.14.10)
Hi, I’m Maciek and have decided to document a 2.35L stroked turbo motor build.
The goal of this build is create a reliable and conservatively tuned daily driver Turbo Legacy capable of 400ftlb/350hp while remaining loyal to the ej22t platform. The manner, in which I chose to achieve this goal, is through a 2.35L DOHC turbo motor.
The car I own is a 1991 Legacy Sport Sedan in pearl white. I have owned this car since 2007 and it is my daily driver. Here are some pictures of the car.
It is running the stock long block with 240K miles. The car makes 270ftlbs and 240hp at the wheels. With the high mileage motor, restrictive 22t heads, and maxed out TMIC; I have decided to build a proper motor for the Legacy.
Following is a list of modifications I have already made:
Engine:
VF39 turbo
06 WRX TMIC
550cc STi fuel injectors
Walbro 255 fuel pump
92 Legacy NA fuel rails
Invidia bellmouth 3” DP
Borla Hush 3” CBE
Coffee mug intake mod
JC Sports cone filter
TurboXS BPV
NKG Iridium spark plugs
Diamond coilpack
8.5mm Magnecor spark plug wires
Lightweight pulley set
Exedy lightweight flywheel
Exedy Stage 1 Race clutch
Group N tranny mount
Group N pitch stop
WRX shift linkage
Hallman MBC
Manual FCD
PP6
Innovate LC1 wideband O2
IC sprayer nooozles
WRX Coolant Reservoir
Suspension:
KYB AGX
GC coilover kit
18-22mm Whiteline RSB
22mm Whiteline FSB
Perrin F/R endlinks
STi trailing links
02 WRX rear lateral links
SimplySubie fender braces
STi front strut tower brace
OBX rear strut tower brace
ALK- 99 Outback bracket with Poly bushings
17” JDM BG5 wheels
215/45 Yokohama S-Drive
Exterior:
02 WRX hood scoop
94 GT sideskirts
RS Liberty rear skirt
30% tint
96 GT projector driving lights
Blinking corner lights
Interior:
Nardi steering wheel
98 GT shift knob
STi shift boot and trim
98 Outback leather heated seats
GC8 A-pillar triple gauge pod
Autometer ES Series Boost gauge
Autometer ES Series Oil Pressure gauge
Innovate AFR gauge
WRX aluminum pedals
The motor build and ECU, wiring and installation, should take me 18-24 months. The motor swap should take place in Summer-Fall 2011. The current motor needs to last that long without any problems….last thing I need is a spun bearing 6 months out from a whole new motor.
I set up 8 sections where I will be adding and updating information throughout the build. When I post updates, I will note on each section the last date of edit.
I have decided to break the build into the following categories:
SECTION 1 – Short Block
SECTION 2 – Heads
SECTION 3 – Intake Manifold
SECTION 4 – ECU and Wiring
SECTION 5 – Transmission
SECTION 6 – Suspension / Brakes
SECTION 7 – Body
SECTION 8 – Miscellaneous
I will comment on the progress of the build throughout the thread, but the bulk of the information will be compiled into the following 8 sections and kept at the fornt of the thread for easy access.
can i buy this i live in colorado man shoot me a text at 303-710-0112
