SiCkSTi04's 1992 Black Legacy SS! ^Updated 12/13^
93legacylsleeper
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 12/16^
Post by 93legacylsleeper »
Not yet but its my next upgrade along with the trans mount and bushings like you did. I might also throw some Perrin Shifter bushings in my STI shift linkage just to make it that much better.... If I get them in before you ill let you know!
SiCkSTi04
Post by SiCkSTi04 »
sounds good to me. tips are always welcome lol
SiCkSTi04
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 03/08^
Post by SiCkSTi04 »
It was a nice day out so I cleaned up both cargo mats that were bought at a local 'you pull it' for my 92 ss and 91 wagon. one was from a 99 legacy outback and second from a 05 forester. Went with the forester mat in the SS as it fit nicely. The legacy mat fit perfect in the wagon.
Here's a couple comparable pictures.
92 SS - Forester 05 cargo mat
91 Wagon - Outback 99 cargo mat
darkcrave
Re: Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 03/08^
Post by darkcrave »
Nice! I so need one of those car mats!?
Tune
TMIC
Fuel
Taillight
Wow incredible fit! Nice score.
SiCkSTi04
Post by SiCkSTi04 »
thanks!
zagarus
Post by zagarus »
Damn those mats are awesome! Car is very well built as well. Am I correct in saying they didn't start painting the intake manifold red until version 2?
SiCkSTi04
Post by SiCkSTi04 »
While the sunroof has been under the knife in my garage, I'd figure its time to take care of a couple small projects.
First up is the fuel pump which has always showed a sign of power loss around sharp corners as talked about in my past thread http://bbs.legacycentral.org/viewtopic.php?f=11&t=45381
This is how the pump should of looked coming out of the fuel tank
But instead it came out with a missing filter like this...
Found it in the second access side of the fuel tank floating lol
Quick size comparison
And finally a brand new Walbro 255 pump & filter
She starts up just fine :)
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 07/23^
Damn....yeah that filter bag shouldn't do that :)
SiCkSTi04
Post by SiCkSTi04 »
Second was filling in that ignoring gap between my aftermarket radio and the bin pocket.
91 bracket w/ 1.5 din (top) compared to 92 bracket w/ 1 din (bottom)
All finished
Danny-G
Post by Danny-G »
Hey I did that too, added the '91 1.5 din box. Also, if you wanna sell the 1 din box I do know someone who would more than likely take it.
Danny
Timo
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 08/01^
Post by Timo »
looks perfect!
Subaru Legacy Turbo RS
Something needed/wanted from EU, maybe I can help, just pm me!
SiCkSTi04
Post by SiCkSTi04 »
Holding the old bin just in case I go back to the oem radio. I got a couple other things I plan on putting in. Thanks for the feedback guys.
SiCkSTi04
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 09/01^
Post by SiCkSTi04 »
Seems my radiator has come to an end, found a large puddle of coolant under my car. Not to bad for 265k miles :?
Currently Looking at Mishimoto's full Aluminum MT or Koyo's OE style radiator but don't care for Koyo's solution creating the AT/MT into one unit for the turbo SS as I don't want the separate transmission cooler. Any input on either of them?
Evidence
Click image below for the video
91legacyawdturbo
Post by 91legacyawdturbo »
Ok what? 91 had a 1.5 din box? My 91ss has a 1 inch din.
2002 wrx sport wagon
magicmike
Post by magicmike »
I put my radio below the din box so i could still read it with the cup holder out.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
SiCkSTi04
Post by SiCkSTi04 »
91legacyawdturbo wrote:Ok what? 91 had a 1.5 din box? My 91ss has a 1 inch din.
I snagged the 1.5 din from a base model legacy.
That is a common failure point for the plastic radiators.
SiCkSTi04
Post by SiCkSTi04 »
Plan on going the Mishimoto route. is there anything else I should do? I'm thinking upgrade the water pump to the WRX so I install my oem oil cooler, timing belt, front seals etc.
Josh, did you run the stock thermostat or wrx when using the new style water pump?
legacymax
Post by legacymax »
Legacy777 wrote:That is a common failure point for the plastic radiators.
failed on my legacy 200mi from home. that was fun!
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
SiCkSTi04 wrote:Josh, did you run the stock thermostat or wrx when using the new style water pump?
Stock thermostat
SiCkSTi04
Post by SiCkSTi04 »
Stock thermostat
Placed a big order for replacement parts including the thermostat, Thanks Josh.
Radiator Update!
Last week I received my Mishimoto Aluminum radiator to find out it was damaged. The vendor I ordered from is sending me a replacement straight from Mishimoto and should have it by next weekend. The plus side is that they dont want this unit back so I'll either fix it, keep as spare or give it away :D
Re: SiCkSTi04's 1992 Black Legacy SS! ^Updated 09/18^
You can give it away to me if you'd like. :)
Florin1
Post by Florin1 »
I'm running an n/a radiator on my tleg. And would love to take this off your hands. I'll pay shipping, and give you some cash? :-D
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
SiCkSTi04
Post by SiCkSTi04 »
Got my replacement from Mishimoto yesterday along with some more subaru parts. I'll deff keep you guys updated if I decide to give the radiator away.
