Page 3 of 24
Re: EJ20G "RobTune" Info
Posted: Fri Apr 30, 2010 10:40 pm
by Florin1
^ 2 different winks. haha
Posted: Fri Apr 30, 2010 10:41 pm
by kimokalihi
Nice score! I will probably buy one too.
Posted: Sat May 01, 2010 6:44 am
by ericem
This is awesome progress if all works out with the ej22t chip I will be all in.
Posted: Sun May 02, 2010 1:56 am
by dscoobydoo
Any pics of one of your EJ20G ecus ( outside case number and pics)?
Posted: Tue May 04, 2010 12:49 am
by Florin1
^ ECU i got back from Rob. I gave him one that had "Z4" on the sticker. It too was a 4 plug.
Posted: Tue May 04, 2010 5:55 am
by dscoobydoo
Trying to figure out if the codes on the outside mean anything.
like the 1C or the Z4
Anyone>>>>?????
Posted: Tue May 04, 2010 6:47 am
by MikeyMeyagi
not once the ecu has been chipped.
Posted: Tue May 04, 2010 7:31 pm
by Florin1
Hey Mikey, how do you like your tune? Have you had it dynoed?
Posted: Tue May 04, 2010 9:32 pm
by fatgc8
Lets get some good reviews so all of us will buy one! lol
Posted: Wed May 05, 2010 3:19 am
by klin7757
dscoobydoo wrote:Trying to figure out if the codes on the outside mean anything.
Anyone>>>>?????
Here's a thread by Rob explaining the different codes.
http://www.rs25.com/forums/f128/t76359- ... codes.html
Posted: Wed May 05, 2010 5:05 am
by dscoobydoo
U8, 2C - 1993/1994 WRX - 11.47psi
W6 - 1993 WRX RA - 11.47psi
W9 - 1994 WRX RA - 11.47psi
SA (STi chipped) - Ver1 STi (Sedan and Wagon) - 14.94psi
SB (STi chipped) - Ver1 STi-RA - 13.64psi
SC (STi chipped) - SAME AS Z4 - Ver2 STi Wagon - 12.78psi
Z4 - 1995/1996 WRX - 12.78psi
Z5 - 1995/1996 WRX-RA - 12.57psi
6K - Ver2 STi Sedan - 13.34psi
7K - Ver2 STi-RA - 13.19psi
Prodrive UK ECU (Prodrive Chipped) -- SAME AS 6K - 13.34psi
1C, 3B, V9, V5 - All WRX Wagons 10psi, dropping to 6.8psi
V7, 7D, 6D - 1993 to 1996 UK/Euro 11.47psi
re-posted so i can refernce later
Posted: Wed May 05, 2010 5:08 am
by dscoobydoo
So Rob, which of these should I get? ( or should I wait for the 22T version??)
Posted: Wed May 05, 2010 5:55 am
by MikeyMeyagi
Florin1 wrote:Hey Mikey, how do you like your tune? Have you had it dynoed?
it runs my hybrid motor way better then the 22T ecu could run it. Rob is going to send me another chip with more timing, probably +4 deg over the base i have now, to compensate for the low comp ratio. if the +4 runs well with no knock, were going to bump it up to +6 or 7 deg and try it. after that i will dyno it.
Posted: Wed May 05, 2010 5:58 am
by Florin1
Oh cool! i will be running a VERY similar set up when its all said and done. Gonna take my 22t shortblock and pair it with my 20g heads and intake w/ FMIC. i'll be very curious to see what you dyno.
Posted: Wed May 05, 2010 6:30 am
by beatersubi
MikeyMeyagi wrote:Florin1 wrote:Hey Mikey, how do you like your tune? Have you had it dynoed?
This is why we need something programmable.
Posted: Wed May 05, 2010 4:50 pm
by rob
Hey thanks. I was looking for the same post I put on Nasioc. I forgot that I also posted on rs25.
dscoobydoo wrote:So Rob, which of these should I get? ( or should I wait for the 22T version??)
If you want to go the G ECU route, then it doesn't matter which of those you pick. Some are more rare than others, so just pick the cheapest you can find. Keep in mind that my G tune on the 22T motors is still a bit of work in progress. So far I only have data from one car. Results look good, but I'm guessing there is still room for improvements that will come with more testing. Plus you need to make doubly sure you know how to match the G ECU to your motor. I am still a bit nervous that somebody is going to skip a step, like picking the right MAF. I don't have a timeline for a 22T tune. Iit might be a bit of a wait.
Just waiting for you give the all clear and I'll fix up a couple new maps for you. Do you see any knock blinks? Have you the tried launch control feature? Does the power curve feel smooth?
-Rob
Posted: Wed May 05, 2010 7:18 pm
by fatgc8
Hey Rob keep up the good work man. I'm sure all of us here really appreciate what your doing and support you 100%.
Posted: Thu May 06, 2010 6:05 am
by MikeyMeyagi
Rob, Power curve is very smooth. No knock ever, light does work though, i lugged the car in 5th up a hill at a lower rpm and got a few blinks just to test the system. LC works, next tune though i want to set my rev limit to 7k instead of 7400, my turbo has no power up that high from what i can tell.
Posted: Thu May 06, 2010 6:09 am
by rob
Sure, no problem Mike. Thanks for the update. Just let me know when you are ready for the next maps to try.
-Rob
Posted: Thu May 06, 2010 6:22 am
by Florin1
Cool to hear.
. Hey Rob any more progress on the COP/WS thing? Just wondering. T think I see a turbo on the horizon.
Posted: Thu May 06, 2010 10:56 pm
by farfrumwork
I'm away for a few weeks and look what I find!!
This is great news. I've wished for Rob to swoop down to rescue us all ever since seeing his work on nasioc. Then the Revtronix fiasco... I had given up hope
And bravo to all those helping out with the development.
If a chipped 22T ECU becomes available I can dyno it up here at altitude (~1mile above sea level) to round out the information. I have Delta 220 cams too, so we could see how the tune compensates.
AWESOME NEWS!!
Posted: Thu May 06, 2010 11:24 pm
by rob
Florin1 wrote:Cool to hear.
Almost ready to test. When are you converting? You game to give it a shot?
Posted: Fri May 07, 2010 2:48 am
by Florin1
I thought you wanted me to hold off on the conversion since you were gonna work on some kind of chip that would save me from having to convert? Unless you mean you already have it in which case, yup I can be ready pretty quick.
Posted: Fri May 07, 2010 2:50 am
by Florin1
Somebody buy my parts from the parts shed so I can make faster progress! This benefits all of us! HAha
Posted: Fri May 07, 2010 5:04 am
by MikeyMeyagi
did i miss something? we already know that 4chan>2chan works mint with dual igniters.....
