RckyMtnLegacy's 93 Turbo...On the Road Finally!
Re: RckyMtnLegacy's 93 Turbo Sedan 'SadPanda' Updated 10-4-1
Be sure to update with pictures of how you mount those side skirts. I have a pair myself that I haven't put on. Painted them black and then didn't like them so I'm waiting until I buy white paint to match the car but who knows when that's gonna be.
RckyMtnLegacy
Post by RckyMtnLegacy »
Oh believe me i will. Not too sure about double sided tape though
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Hell no. I'm probably going to use some but just to keep the skirts in place better. I'm going to fasten them on with some other brackets. I don't like things flying off my car on the freeway. Or other people's cars...that means you whoever is double-sided-taping things onto their vehicles!
RckyMtnLegacy
Ha... and the underside of my car is almost 20 years old and not the cleanest surface even if i scrub it.
I believe the double sided tape goes on the sides of the car under the doors.
xise
Post by xise »
nice progress man, I like your style haha. Sorry to hear about all your misfortune! If you are looking for some good hoses for oil use check your local genelco, they carry aeroquip hoses which are specific for oil and high psi oil/ hydraulic lines, and if you buy their fittings they will assemble your hoses for you!
RckyMtnLegacy
Thanks a lotthanks a lot
subytech
Post by subytech »
sorry about not getting back to you on the sleaves, no you cant use the block, you wouldn't be able to get the wrist pins out if you left the sleave like it was,and if the block has overheated that badly I would worry about the sleaves being loose. You would have to re-sleave the block.
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
RckyMtnLegacy
Well good thing its my paper weight now
RckyMtnLegacy
Well block has been split apart. Rod#4 bearing spun and was torn up. Block is at the machine shop with the crank to be bored 20 over for my new Wiseco pistons and Eagle rods. Very excited!
RckyMtnLegacy
So you know all those snags I keep finding? Ya got two more. Crank with the spun bearing cannot be turned since they don't make bearings that size. Then my spare crank from the block I had before is also bad. The machine shop I go to has a crank std size polished with ACL bearings for 250 so that's going to cut into my wallet Monday. Dam dam dam
RckyMtnLegacy
http://www.unionperformance.com/02-07-s ... t-catless/
Will this bolt up to the vf11? I can't remember. I plan to make brackets and just Straight pipe it out the side but I have no downpipe since I sold it to some kid
Yes, it should bolt up to the stock turbo. It won't fit the rest of the stock exhaust, but for you it sounds like that won't be a problem.
RckyMtnLegacy
Awesome. For like 80 bucks new seems ok. I was going to pick up a buddies but he wants 100 bucks.
RckyMtnLegacy
Oh and the crank i was going to pick up us no longer available. So i had to road trip out to find another one but it still needs to be machined. Hurry up and wait game continues
RckyMtnLegacy
Block is assembled and putting pistons in now
RckyMtnLegacy
Ok so my rebuild is underway and I had most of the gaskets that I need. My set didn't come with the o-rings that go between the block halves. I bought some o-rings that matched the old ones from Oreillys. I am being told that this is a bad idea and I have to use Subaru Specific o rings so they don't break down inside. Has anyone used over the counter o rings or do I have to go to Subaru specific ones. I don't want to take the motor apart again but I would rather be safe than sorry.
RckyMtnLegacy
So I am now waiting for O-rings from Subaru and I hate waiting. But oh well gotta do it right.
Parts that did arrive.
Last edited by RckyMtnLegacy on Tue Dec 13, 2011 7:03 am, edited 2 times in total.
RckyMtnLegacy
Keeping them nice and cozy
RckyMtnLegacy
Before I had to take it apart to replace the o-rings inside
I think I may have damaged the seal installing it so I guess I'll try again.
RckyMtnLegacy
Figured while I waited I would clean up my 'new to me' bumper
Something is missing but not sure what...Waiting to find the missing link before I start on the side skirts
music station a real must have
Are you planning to replace the stock head bolts with ARP studs? Personally, I'd recommend it.
Also....I hate putting in that damn rear crank seal. It's a pain in the butt!
RckyMtnLegacy
Legacy777 wrote:Are you planning to replace the stock head bolts with ARP studs? Personally, I'd recommend it.
Yep i already have the studs they were installed during the last rebuild. How tight do they go into the block before placing heads on?
Try and clean the stud holes out as best you can, and the studs should be bottomed out. What I did for mine was screw in the studs snuggly into the block, but not super tight.
SUBYLUV871
Post by SUBYLUV871 »
ya go-pro. those are the best thing ever . looks good. its goin to be nice havin your ride back.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
