The steering wheel needs a roll connector from a newer Subaru which just plugs in to the under dash harness. Mine was from a '98 Outback. My original cruise switch wouldn't work easily, so I used the WRX cruise switch which did work. The horn is a simple plug-in deal and it works. The airbag does not work since the firing system is completely different, so I had to block off the "AIRBAG" warning on the cluster. I pulled up the fascia and stuck a piece of electrical tape over the airbag light from the back so you can't see it and it blocks the light perfectly.
The steering wheel makes a big difference in how the car feels to drive, it's just so much nicer than the stock wheel.
 . Also think it was your car that made me want to get the Yakima rack and fairing. Love the color you have on the wheels, what color is that if you don't mind.
 Only once I've seen one with my bare eyes.
 I installed the alarm the other day and finally having keyless entry again is awesome! Hopefully I'll be making a tint appointment for next week, I have a day off coming up and would love to get this thing tinted. I'm gonna go for 20% all around I think.
