Page 3 of 4
Re: '94 SS Daily Driver
Posted: Thu Mar 01, 2012 5:38 pm
by Alphius
Ha, I just assumed you meant the WRX wheels. :lol:
The steering wheel needs a roll connector from a newer Subaru which just plugs in to the under dash harness. Mine was from a '98 Outback. My original cruise switch wouldn't work easily, so I used the WRX cruise switch which did work. The horn is a simple plug-in deal and it works. The airbag does not work since the firing system is completely different, so I had to block off the "AIRBAG" warning on the cluster. I pulled up the fascia and stuck a piece of electrical tape over the airbag light from the back so you can't see it and it blocks the light perfectly.
The steering wheel makes a big difference in how the car feels to drive, it's just so much nicer than the stock wheel.
Posted: Sun Mar 18, 2012 1:08 am
by SILINC3R
Was stumbling around the search looking for cars with painted rims and found your car. Then I realized I have the older version of your car :wink: . Also think it was your car that made me want to get the Yakima rack and fairing. Love the color you have on the wheels, what color is that if you don't mind.
well here is picture of mine, not as nice as yours but its a work in progress of course.
and in regards to the manual crank, I have a 89 and it doesnt have manual windows but then again that might be because its an LS.
Posted: Sun Mar 18, 2012 5:51 pm
by Alphius
Mine actually has the stock color rims from an '05 WRX. Subaru calls the color "Bronze". They are a slightly different design than the 02-03 WRX wheels, but still a 10-spoke 16x6.5 wheel.
The manual crank windows were on a base model Legacy with silver painted steel wheels, it didn't have A/C or power locks or even painted bumpers! It was an interesting looking car. It was a 5 speed FWD.
Thanks for the kind words! I enjoy your Rio Red SS a lot. My '91 SS was Rio Red as well, but it didn't look nearly as nice as yours! :-)
Here's mine:
Posted: Sun Mar 18, 2012 11:37 pm
by SILINC3R
No problem, and thank you as well. Is your car considered Rio Red or is it Ruby Mica or something lik that?
Posted: Mon Mar 19, 2012 5:02 am
by Alphius
Yeah, the one I have now is "Crimson Pearl". It was a one year option in '94 only. Lighter than Winestone, darker than Rio Red. Not quite the same as Ruby Mica, but kind of similar.
Posted: Mon Mar 19, 2012 7:49 am
by Thesubielover
Was your dad up to paint there stuff? I was wondering because my hood scoop and spoiler need it too. Not badly but will need to be done at some point. What is the trick to blacking out the trim? Electrical tape and an exacto knife?
Posted: Mon Mar 19, 2012 11:21 pm
by Alphius
My dad's painting is out of commission for a while now since they're in the process of buying a new house and selling the old one.
The trim can be blacked out with electrical tape, mine is holding up fairly but there's a couple sections I need to redo. My only advice would be to use the best electrical tape you can get, like 3M brand or equivalent. Cheap .99c electrical tape won't hold up for more than a few weeks.
Posted: Thu Mar 22, 2012 1:53 am
by Thesubielover
How do you set it up? Put it on and cut off in the deep line sections of the trim with an exacto knife? Or just use the whole width of the tape?
Posted: Thu Mar 22, 2012 3:07 am
by Alphius
I used the whole width. It is unnoticeable unless you look really closely. I experimented with cutting with an x-acto knife but it didn't work very well; some silver always shone through after a few minutes. The tape seems to contract a little when you put it on.
Posted: Mon Jun 04, 2012 10:34 am
by KristjanJohann
OMG! I love it. I'd love to get my hand on a Turbo Legacy :D Only once I've seen one with my bare eyes.
Posted: Mon Jun 04, 2012 3:19 pm
by Alphius
Thank you for the compliment! A Turbo Legacy must be a rare car in your country.
Posted: Tue Jun 19, 2012 5:42 pm
by Alphius
I bought a set of factory shifter bushings when I bought the car over a year ago.
I finally replaced them a couple weeks ago. Holy crap! The shifter feel is so much more direct now! It doesn't feel rubbery anymore, and almost all of the play is completely gone. What little play there is left is from the shift forks inside the transmission. In short, if you don't want to pay for a knuckle and newer shifter from another car, just replace the factory bushings and your driving experience will be very much enhanced.
I didn't even have any trouble with the rollpins on the linkage. A nice set of appropriately sized stainless steel punches took care of them very easily.
A++ mod would do again.
Posted: Tue Jun 19, 2012 5:56 pm
Alphius wrote:A++ mod would do again.
"Like"
:D
Posted: Thu Jul 05, 2012 4:23 pm
by Alphius
I put on some nicer body parts the other day. Fixed up my loose door handle. Took the pinstripes off. Then I washed it all up. I also ordered a keyless entry/alarm system that I'll be installing in the next couple weeks. The car is looking really good! I think tinted windows are in the cards soon as well.
I also wanted to show my 5-channel amp setup that powers all 4 Kicker surround speakers and a small Memphis sub in a sealed box in the trunk. It all runs off of my Pioneer headunit. I installed all this a few months ago and it still sounds great. Much better than running the speakers off of the headunit, even though it is a good quality headunit it just can't compare. I tried to install everything very cleanly as well, I think I succeeded.
Posted: Thu Jul 05, 2012 5:42 pm
by SILINC3R
Looks really good, I did the same thing with a 10 disk changer. I was also suprised by how much better the shifting felt after replacing the bushing. I agree on the tint, makes the color pop more in my opinion.
Posted: Sat Jul 07, 2012 5:30 am
by randomiam
Looks great. Pretty swell ride you have. I'm certainly jealous.
I like the corrugated casing you use for the wiring..
Posted: Tue Jul 10, 2012 2:33 am
Looks good! Second the tint.
Posted: Tue Jul 10, 2012 9:50 am
by Thesubielover
I like it! Looking great. Where did you find the wheels? Did you sell the old ones?
Posted: Tue Jul 10, 2012 3:46 pm
by Alphius
On the stereo wiring, the corrugated tubing really does clean it all up. When the seatback is up, the bare wiring right at the plugs is hidden by the small sub box which is carpet-matched to the factory trunk carpet. From the seatback, all the wiring runs under the rear seat cushions and up to the stereo and battery completely hidden of course.
The wheels are the same ones I've had on the car since I bought it. 2005 WRX wheels in factory bronze. For a day or two I had a set of 2006 WRX 17" wheels on there but I didn't really like them so switched back. The bronze color goes really well with the crimson pearl.
Thanks guys! It really photographs better than it looks in person, but I try to keep it nice enough. :) I installed the alarm the other day and finally having keyless entry again is awesome! Hopefully I'll be making a tint appointment for next week, I have a day off coming up and would love to get this thing tinted. I'm gonna go for 20% all around I think.
Posted: Tue Jul 10, 2012 11:28 pm
by Thesubielover
Still have the other wheels? ;)
Posted: Wed Jul 11, 2012 5:40 am
by Alphius
No, I got rid of them a while back.
Posted: Fri Aug 24, 2012 1:26 am
by Subi-swap94
Alphius- how did you change your grill like that?
or did you buy the car like that?
Posted: Fri Aug 24, 2012 4:50 am
by Alphius
I cut the factory grill out until it was just the outer frame, then I used plastic epoxy to fill in the holes left by the crossbar and it's supports. I then took a piece of gutter guard mesh and epoxied it to the grill after trimming to shape. After all that, I masked off the colored part of the grill and hit the mesh and black plastic with flat black engine enamel. It's like the rest of the car, looks good from 5 feet back but you can see what I did when you get close since I didn't sand the epoxy enough. ;)
I think the grill mod really made the front of the car look better, especially in combination with the EDM glass headlights.
Posted: Sun Aug 26, 2012 7:36 am
by Dominator
Your car is looking really nice. I want to do most of the mods you've done. :)
I'm still on the hunt for an intermittent wiper stalk. I hope it's compatible with the 91's, I read what Kimo was saying about it, and maybe that's something.... We'll see.
On a different note, regarding the manual crank windows. I saw a car with them today. Was at an auction, it was a 91 Wagon, no ABS, no A/C, Crank windows, Automatic. Was AWD too. Very low-end base model.
VIN: 4S4BJ63C2M7904004
Posted: Wed Oct 24, 2012 10:34 pm
by Alphius
