So I was noticing some noises coming from the rear of this car. Figured it was a strut as I have been traviling a lot of really, really rough dirt roads, going back and forth between my parents place, and the place I recently purchased. So I put it on the lift the other day to check it over. Turns out the sway bolts had loosened and fallen out of the body. It wore one of my links down, and ruined the threads in the body. I had to take the filler neck out and rethread the body, but everything seems to be ok for now. I have a lot of work to do after the Turbo comes out for the summer. I need to paint the rear hatch again... and touch up some other rust popping up here and there. I also need to replace or weld my header it has a hole in it, unfortunately it is on top of one of the pipes, so I need to remove it to weld it. Right now I'm just trying to make it to the end of the winter so I can start to fix this thing....
In front of the new place. Don't worry I have a garage.
