Page 3 of 5
Re: Brake Journal/Idea Log *UPDATED 10.09.12*
Posted: Sat Oct 13, 2012 4:18 am
beatersubi wrote:Legacy777 wrote:Just another thing with the struts & brake lines, what myself and others have done is just cut a slit in the strut that you can bend down and slide the brake line in and then bend the tab back up. That keeps you from having to open the brake system up.
I know that you meant to say the brake line holder tab, but I'll specify just for safety's sake.
Another thing to try on the caliper pistons is emery cloth.
Thanks! Edited for clarity
Posted: Sat Oct 13, 2012 4:30 am
by originalcyn
Thanks for all the suggestions guys! do the kyb struts have the same tab?
i don't think i want to paint the inside of the pistons, does that mean i should just leave them be?
Posted: Sat Oct 13, 2012 5:20 am
by SILINC3R
Yes they should as they are direct replacement parts. Yes you can leave them be. They are not painted from factory. If you want to you can just put a very thin amount of grease on the metal to keep it from corroding.
Posted: Sat Oct 13, 2012 7:05 am
by originalcyn
SILINC3R wrote:Yes you can leave them be. They are not painted from factory. If you want to you can just put a very thin amount of grease on the metal to keep it from corroding.
Thanks! I guess what I meant though was, should i not bother sanding them out at all since they'll immediately get corroded again. Or maybe I should sand them out and then grease them? How long will the grease keep them from corroding?
Posted: Sat Oct 13, 2012 8:55 am
by kimokalihi
I seriously doubt you'd be doing yourself any good even bothering with the insides of those cups. They last for the lifetime of the car with no paint or grease so you're just wasting your time.
Posted: Sat Oct 13, 2012 5:00 pm
by beatersubi
I can verify that KYB struts do have the brake line tab. I've had both AGX and GR2s, and they've both had it.
Posted: Sun Oct 14, 2012 3:46 am
by originalcyn
kimokalihi wrote:I seriously doubt you'd be doing yourself any good even bothering with the insides of those cups. They last for the lifetime of the car with no paint or grease so you're just wasting your time.
Ok, that's what i was starting to get from this conversation. Thanks Kimo.
beatersubi wrote:I can verify that KYB struts do have the brake line tab. I've had both AGX and GR2s, and they've both had it.
Thanks beatersubi, That's good to know.
Posted: Mon Oct 15, 2012 12:51 am
by originalcyn
Posted: Mon Oct 15, 2012 3:40 am
What type of solvent? Use a brake cleaner that doesn't have petroleum distillates in it. It will dry cleanly without a residue. I would think the powder coaters will clean and prep as well.
Posted: Mon Oct 15, 2012 4:02 am
by originalcyn
blarg, so i did the work at my friend's dad's shop. He let me use his sandblaster and he cleaned up all the parts afterwards using his solvent sink. I think it was mostly paint thinner at that point. That being said, there was no apparent residue. The discoloration only happened after i used the wheel cleaner. Mayhapse the paint thinner left residue that reacted with the wheel cleaner. But, i don't think a little discoloration will matter after powder coating. I'm not sure the powdercoat guy will do any prep work. I never really ask him what he does because i feel like he's doing me a favor since he does the stuff for me so cheap. Maybe he does. We'll see.
Re: Brake Journal/Idea Log *UPDATED 10.15.12*
Posted: Tue Oct 16, 2012 12:07 am
by originalcyn
Sent everything off to be powdercoated today. it'll be 50 dollars according to the guy. I asked him to stay away from anything machined, but it sounds like he's done this before.
Question though, Do i need to be worried about the added thickness of the powdercoating on the calipers and brackets?
Posted: Tue Oct 16, 2012 5:56 pm
No I don't think it should be an issue, and you should have enough room to get the pads on and caliper swung down. How much added thickness will be there?
Posted: Wed Oct 17, 2012 1:24 am
by originalcyn
I'm not really certain, that's the problem. I don't think it adds that much, maybe a couple millimeters on either side? But again, i don't have a point of reference on this.
Posted: Wed Oct 17, 2012 3:01 am
by kimokalihi
Couple milimeters? No way. That's huge. It'll be fine.
Posted: Wed Oct 17, 2012 4:34 am
by originalcyn
Oh man, you're completely right. I read that "Thickness can range from 1.5-6 mils. Our one coat standard is 3-4 mils."
Then assumed mils was mm for what ever reason, but it's actually 1 mil = 0.0254 millimeter or 1 mil = 0.001 inch. So at most .1524 mm on each side of the bracket, so a combined thickness of a little less than 1/3 of a mm.
Posted: Wed Oct 17, 2012 5:59 pm
Units.....that's what caused a martian space ship to crash
Posted: Wed Oct 17, 2012 7:57 pm
by originalcyn
units and physics. My worst enemies.
Posted: Thu Oct 18, 2012 5:41 pm
I never really consistently carried the units properly in college. It wasn't until I started studying for my professional engineering license that I really focused on it. They would put the wrong answer in the exam to trick people that didn't include the conversion factors for units.
Plus, if you sit down and look at what you're given and what you want, you can kind of do the unit derivation which helps in determining the path/formula(s) to use.
Posted: Sat Oct 20, 2012 12:43 am
by originalcyn
I've always been terrible at math. Up until Calculus i didn't have to study for tests if i paid attention in class. But Calculus wrecked me. Even basic additional and multiplication take me forever to do in my head.
So the calipers and brackets came back from the powder coater. As usual, the job was a little sloppy, but over all fine for the price.
None of the piston bores have any coating in them fortunately, but around the lips of the bores there's some burrs. I need to figure out how to smooth them out a little.
Re: Brake Journal/Idea Log *UPDATED 10.19.12*
Posted: Sat Oct 20, 2012 1:50 am
by originalcyn
Jumped the gun and did some practice with the vinyls.
Posted: Sat Oct 20, 2012 2:43 am
by kimokalihi
Looks pretty good.
Posted: Sat Oct 20, 2012 2:58 am
by originalcyn
Thanks Kimo. It's a little thin in some areas, but fine. Still trying to clean up the burrs, hoping they won't screw up the caliper rebuild kit.
Posted: Sat Oct 20, 2012 2:59 am
by beatersubi
If that where the lip of the boot sits, it should be fine.
Posted: Sat Oct 20, 2012 3:12 am
by originalcyn
Yeah, it's only around the very top. Nothing got into the bores, just some clumping or something around the top rim.
Posted: Sat Oct 20, 2012 3:18 am
by beatersubi
If its in the way of the boot, take some emery cloth or sandpaper to it. Be careful not to chip it though (it take a bit to do so), as the metal underneath will oxidize around the chip and its difficult to seal.
