ej22 na turbo help pls
Re: ej22 na turbo help pls
Ok, good to know.
bcmaxx
Post by bcmaxx »
Looking for a bit more fuel. At 16psi its a bit lean at 12,3 ish when im hard on the gas. Rrfpr is maxxed. Can i do anything to the stock injectors or swap in my ej22t injectors and rails ? Im on the smallest water injection nozzle. Upping one size help?
You wouldn't really be able to swap injectors since the ECU is matched with the injectors and swapping in a turbo Legacy ECU isn't going to work either.
Do you have a higher flow fuel pump? You could try a different RRFPR with an increased rising rate.
bcmaxx
Post by bcmaxx »
Ive decided to run lower boost until i get the turbo block finished and in. It will likely have different fuel demands with a lower cr. Currently running a holly variable rrfpr and meth injection
bcmaxx
Post by bcmaxx »
Fixed! It was suggested I clean my maf, cleaned, and now I have all the fuel i need.
bcmaxx
Post by bcmaxx »
Another odd question. I need to replace my turbo oil feed line. My bastards tee fitting off the oil press sensor location is leaking a bit. What is recommended size? Im using 1/4 inch tubing at the moment.
The first post of this thread http://sl-i.net/FORUM/viewtopic.php?f=39&t=22065 shows you a good option for an oil feed line for the factory non turbo setup.
Might be something to try?
bcmaxx
Post by bcmaxx »
Thanks! I found another on there too http://www.ebay.ca/itm/MK1-Turbo-Oil-Fe ... RTM1963930
but not sure if it will work?
