RobTune: knock light flickering
robertpaige
Re: RobTune: knock light flickering
Post by robertpaige »
His name on here is noyst, white wagon in Canada.
rob
Post by rob »
I do not keep track of forum handles. Privately send me his email address.
rob wrote:Thanks for the review and suggestions Josh. I hope you didn't run out of red font :) For my first attempt I was aiming to cover all of the technical details and make sure it made sense. I didn't see any edits there or have any questions so will assume it is clear.
-Rob
You're welcome Rob.
Bcaron1000
Post by Bcaron1000 »
I'm getting the knock flash upon start up and it's literally shaking my entire car
robertpaige
Bcaron1000 wrote:I'm getting the knock flash upon start up and it's literally shaking my entire car
Sounds like you have a real misfire or something else seriously wrong if the car is shaking. My car never had it that bad. My questions were while in boost under load in 4th/5th.
Run your codes and see if you're getting any trouble.
Bcaron1000
I don't have any codes showing up.. it's like the drivers side of the motor isn't sparking as good as the passengers side.
robertpaige
Bcaron1000 wrote:I don't have any codes showing up.. it's like the drivers side of the motor isn't sparking as good as the passengers side.
EJ22T?
Get new plugs and wires, get v-power copper and gap them to .038
If still rough, try and swap the coilpack with a known good one.
