Page 3 of 5
Posted: Thu Jun 03, 2004 3:55 pm
by 123c
Legacy777 wrote:It's called the abs ring. I could look it up when I get home. What year, model, etc car do you have?
1993 Legacy SS
Tone Wheel Front: 26750AA003
Posted: Wed Jun 09, 2004 9:07 pm
by 123c
New part number needed, I can't seem to find, even in that nice parts reference book Josh provided, and Subaruparts.com can be a little confusing at times.
I can't seem to find the number for the little rubber boots that go over the slide pins on the brake calipers, one of them has a small tear, so I figure I should replace it, and probally all of them...
Posted: Thu Jun 10, 2004 1:13 am
You can't buy just the boot, however you can buy a rebuild kit that has the boots, seals and lube
Depending on when your car was made....there's two different #'s
If it was made on or before sept of 92 the # is
26297AA020
If it was made on or after oct of 92 the # is 26297AA021
Posted: Thu Jun 10, 2004 5:11 pm
by 123c
Do the rebuild kits also come with the anti-rattle clips?
Posted: Thu Jun 10, 2004 6:12 pm
no.....just the parts to rebuild the caliper
Posted: Sun Jun 13, 2004 2:14 am
by 123c
Ok, here's another part I can't seem to find, I am looking for the bushings that go into the Stabilizer Link Assembly. I can't seem to find it, I can only find the Stabilizer Link Assembly, but no bushings for it.
Posted: Wed Jun 16, 2004 11:54 pm
by eastbaysubaru
I hope this is an easy one. I've got a few Grill Clips that are broken. The lower middle clip and the clip attached to the passenger side headlight are both broken. Does anyone have the part number for these clips? TIA.
-Brian
Posted: Thu Jun 17, 2004 12:46 am
by 123c
outer clips: 91017AA010
inner clips: 91059FC090
Posted: Thu Jun 17, 2004 5:17 am
by eastbaysubaru
Which is which? I need one of the ones that attaches to the headlight (outer?) and one that attaches in the center on the bottom (inner?). Outer and Inner seem like they refer to the top clips as there are four of them. The ones that I need are the ones that the grill slides down onto.
-Brian
Posted: Thu Jun 17, 2004 10:10 pm
by eastbaysubaru
Front wheel bearing:
28016aa011nt
Seals for associated bearings:
28015aa070 (inner?) not sure which is which
28015aa021 (outer?)
-Brian
Posted: Thu Jun 17, 2004 10:25 pm
The front wheel bearing should be part number 28016AA011. The inner seal is part number 28015AA021 and the outer seal is part number 28015AA070.
I think you need a snap ring for one or both seals; the snap ring is part number 28035AA010.
Posted: Fri Jun 18, 2004 5:01 am
by eastbaysubaru
Thanks for the extremely helpful reply Vikash. The part number for the wheel bearing has been superceded by the part number I listed:
28016AA011NT
-Brian
Posted: Fri Jun 18, 2004 2:26 pm
Cool.
I didn't see that you had edited your post. (That's what happened, right?)
An odd thing I noticed -- the GD-chassis WRX/RS has the same part numbers except for the inner seal which is part number 28015AA080. I would have expected it to be the same.
Posted: Fri Jun 18, 2004 3:55 pm
by eastbaysubaru
Yeah, I edited it as I was calling the local Oakland dealership. They were actually pretty helpful this time and gave me all the associated part numbers that I needed. They didn't tell me about the snap rings though, so thanks!
-Brian
Posted: Fri Jun 18, 2004 11:07 pm
by 123c
As far as I know, there are no snap rings. I just had my bearing pressed last week, and the machine shop didn't say anything about one...
Posted: Mon Jan 24, 2005 7:18 am
by ferre
hi all
i'm wondering if anyone would know where i could get the part number for a JDM 2lt gt legacy auto ECU
or even better would be if anyone knows of a parts list for JDM legacy's
i noticed a similar question posted earlier in this thread but it was from awhile ago so i though i would ask in case there is any upadtes
Posted: Mon Jan 24, 2005 4:10 pm
Hmm....I don't have any JDM part #'s
There might be someone else.
Have you tried
www.rslibertyclub.org/forums ?
Posted: Wed Apr 20, 2005 7:30 am
by THAWA
Does anyone know the part number for the v8+/USDM STi, Legacy GT/Outback XT, Legacy 2.0GT oil pan. The twin scroll one?
Posted: Wed Apr 20, 2005 5:41 pm
is it different?
Posted: Wed Apr 20, 2005 8:38 pm
by THAWA
quite
Posted: Wed Apr 20, 2005 11:57 pm
how so? and what if any are the benefits....or is it just a fitment issue?
Posted: Thu Apr 21, 2005 1:04 am
by THAWA
It is shaped to allow the use of twinscroll headers.
Posted: Thu Apr 21, 2005 2:23 am
by dzx
I remember hearing about twinscroll turbos but i dont remember what subaru's they come on. I do remember that there are quite a few differences in the setup.
Posted: Thu Apr 21, 2005 2:30 am
by THAWA
They come on v8+ STi's and Legacy 2.0GT's
Posted: Thu Apr 21, 2005 3:17 am
None that came in the USA correct?
