A vacuum hose reference for EJ22Ts
94Turbro
Re: A vacuum hose reference for EJ22Ts
Post by 94Turbro »
Can anybody tell me what size hose is used for #4 on the PCV system?
1994 Legacy SS: TD04, FMIC, Daily baby hauler/ Hoon cart.
I'm assuming you're referring to #4 on this diagram?
http://www.surrealmirage.com/vrg3/vacuum/ej22t_pcv.gif
If so, the closest size is going to be 3/4".
94Turbro
Post by 94Turbro »
Thanks Josh, you the man as always.
94Turbro
Post by 94Turbro »
Are the number #8 #9 #10 #11 and #15 hoses in this diagram (http://www.surrealmirage.com/vrg3/vacuum/ej22t_pcv.gif) 1/2"?
I'd have to double check on those, I'm not 100% sure.
I think they are.
208ss
Post by 208ss »
What size hose is #4 on pcv system and does it go to the rear port or iac
1991 subaru legacy sport sedan
just-rust
Post by just-rust »
Check this out 208 -
Legacy777 wrote:I'm assuming you're referring to #4 on this diagram?
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Soobster
Post by Soobster »
Does anyone know if the September 8th 2004 version of the EJ22T Vacuum Hoses diagram is the most recent? Earlier in the thread, vrg3 mentions making updates a few times?
1987 VW Westfalia Vanagon - EJ22T Powered
1994 Legacy Touring Wagon
What's on the site http://www.surrealmirage.com/vrg3/vacuum is correct.
Soobster
Post by Soobster »
For replacing the 5.5mm vacuum hose with aftermarket silicon hose, would you guys recommend using 5mm or 6mm? It does not look like 5.5mm is an available size. Same for the 7.5mm. Better to go slightly over or under?
I would recommend 5mm. It'd be a little bit more snug.
Soobster
Post by Soobster »
Any recommendations on a brand/vendor for silicon vacuum hose? I guess they are not all created equal. Platinum curing, thin wall vs. thick wall...hard to know what's real and and what's real BS.
I've gotten quality stuff from silliconeintakes.com
Bobsaget
Post by Bobsaget »
This is a very helpful thread! Thank you guys for all the information!
