Page 4 of 8
Posted: Tue Nov 15, 2005 12:25 am
by subawhatsubawho
"This will decimate all after we put about ten grand into it. We can overnight parts from japan."
"Put it on my tab at harry's"
by bmxpunk
Nico, how much boost are you running on what turbo?
Posted: Tue Nov 15, 2005 1:01 am
by Natoe
ahhh i finally read this thread. NICO- i really like the look of your car, especially the wheels+tires.
i dont know if you know me, im doing the same swap, in a 95 impreza coupe, cept FWD :( im looking for a parts car to make it AWD since MY clutch is soooo slippy. ( i had it running on the 1.8 ECU but now im rewiring)
did you use the 1.8 engine harness adapted to fit on the 22t? thats what i did, and am putting my ECU where the impreza ECU goes.
can i ask you what all you did to get ignition to work? is there anything special? i know i gotta put a diode somewhere for self-shutoff control. anything else i should look out for? i got the B47 connector all spliced and hooked up to the ECU, 3 more connectors to go!
thanks, and nice car
Posted: Tue Nov 15, 2005 1:32 am
by evolutionmovement
Nico - You're dad's probably right about the wheels if they are real mags. 'Mag' wheels were originally called that because they contained a lot of magnesium. They were very light, but somewhat fragile and magnesium has a bad habit of burning so they don't use it as much, if at all, for wheels any more. BMW, for one, is using it in engine blocks now. I suspect it's an interesting alloy, though.
Posted: Tue Nov 15, 2005 3:40 am
by bmxpunk
Natoe, He did all of the wiring like yours. and his dad did the port and polish like me.
I just got the equal length exhaust manifold for my car. I need to port them out and then get them ceramic coated. I am gonna get a higher temp coating this time. So if either of you guys are looking at new exhasut manifolds in the future.
Posted: Tue Nov 15, 2005 3:49 am
Didn't Porsche make some engine blocks out of magnesium too? I remember a firefighter once telling me about how they put out an engine fire and afterwards found that there was no engine block left.
Posted: Tue Nov 15, 2005 4:28 am
by dzx
That's interesting, I know it takes at least a propane torch to set off magnesium. So its not like if someone drops a ciggarette next to it, its going to go off.
Cool thing about magnesium is you can use to to set off a reaction with aluminum and Iron(III)? oxide (aluminum shavings and rust in a powder form). Which has many cool uses.
Posted: Tue Nov 15, 2005 4:36 am
by wiscon_mark
dzx wrote:Cool thing about magnesium is you can use to to set off a reaction with aluminum and Iron(III)? oxide (aluminum shavings and rust in a powder form). Which has many cool uses.
Yeah, Iron(III) oxide. Its not actually a spark, its just a catalyist. Magnesium itself doesn't start the reaction, it just makes it a hella lot faster.
I think. lol
Posted: Tue Nov 15, 2005 5:11 am
by subawhatsubawho
My old Panasonic toughbook's case was made out of Magnesium. When they tested it for CR they stuck it in the oven at 350 for 30 minutes and it survivied.
This is the same laptop that cops and military personell use in the feild. The HD's are surrounded by a gel that suspends them in the caddy so it won't get hurt if you drop it.
Posted: Tue Nov 15, 2005 5:52 am
Magnesium burns very hot. The problems occured when a regular car fire burned near the wheels.
Porsche did use magnesium and might still to some degree. IIRC, the 2.7 in the '70's Carrera RS had a magnesium case with nikasil liners. I'm no Porschephile so that's from a hazy memory mostly 'cause that's one of the only Porsches I'd like to own (or at least a replica with a 3.0 built from a 911SC).
There have been a lot of mfg, using magnesium, but it's usually reserved for racing. I mentioned BMW as I they're one of the few (only?) doing it today with a road car block.
Posted: Tue Nov 15, 2005 6:33 am
by entirelyturbo
I heard a tale of a old Corvette that had a tire blowout, and the magnesium wheel caught fire. The whole car burned into smoke because of that one wheel, coz they couldn't put the fire out.
IIRC from my chem class in HS, magnesium has to be 100% immersed in water in order for the flame to be extinguished.
Posted: Tue Nov 15, 2005 7:42 am
by subawhatsubawho
Are you thinking of tracking down a mag rim to try and watch it burn?
Posted: Tue Nov 15, 2005 9:13 am
by NICO
evolutionmovement ya they are magnesium i couldnt spell it so i siad "mag" the fiat rims are very very light and soft
hahaha you guys are crazy, you want to melt a rim down for a test, take pics i want to see hahaha.
subawhatsubawho hahah lets just say i got conections, but i cant abuse them to make money so i just get what i need and go.
Natoe & bmxpunk, no the way me and my dad did it was we striped the hole car down, put it a side then we stried my legacy turbo, took what i needed and scraped it. i also had striped another turbo legacy down before the swap, it was a A/T. i used the better wirieng for my impreza. we layed the hole wiring, i mean the hole wiring front to back of the turbo legacy A/T car. then we wired up, the tail lights, the door lights, and the dash with heater controls, becuse they where all diffrent. thats the only thing you need to wire up from a impreza to legacy.
then we put the motor in and all the other stuff like dash carpet and so on. after all that we tested everything to make sure it was all working good and it was.
Natoe where the impreza ecu is i put my e-manage. the factory ecu in a turbo legacy is under the dash, it can only go there so i put it under the dash in the impreza also.
bmxpunk the turbo in the pic is a t-bird/factory up grade, it gets to 18psi and then drops to 17psi up top
Re: Weird
Posted: Tue Nov 15, 2005 4:43 pm
by rallysam
mouth564 wrote:
Awesome!
I keep having these strange thoughts any one know why? xx(xx(
Why do your posts make no sense and why do you have a bunch of advertisements for online gambling? Are you a spambot or something?
Posted: Tue Nov 15, 2005 7:24 pm
by subawhatsubawho
As my oldest son would say in his robot voice..." I AM ROBOT I WILL EAT YOU! LCO SPAMBOT MUST BE BANNED!"
Posted: Tue Nov 15, 2005 7:58 pm
by 206er
as I recall, only certain magnesium will burn, pure maybe? dont remember. most everything car related made of magnesium is an alloy. Type 1 VW aircooled motors have magnesium cases.
once you do get magnesium burning though, theres not much that will stop it.
Posted: Tue Nov 15, 2005 10:32 pm
by 555BCTurbo
Yeah, when I worked at a VW Wrecking yard, we used to get people wanting to buy engine case halves to make bonfires on the beach...
Idiots...
Posted: Tue Nov 15, 2005 10:36 pm
by subawhatsubawho
I wonder if they explode and pieces fly off like other materials tend to do when heated?
Posted: Tue Nov 15, 2005 11:54 pm
by 0perose
must... build... one of these.......................
Posted: Wed Nov 16, 2005 1:31 am
by Binford
VW block fires are cool! Kind of a bitch to light, but it lasts all night long. If you can, con somebody into taking a leak on it. They'll never do it again! :lol:
Edit: NICO, nice car! I'm thinking of finding a two door and and doing a semi-22b replica.
Posted: Wed Nov 16, 2005 1:46 am
by NICO
you guys are crazy hahah u use engien blocks for a camp fire.
Binford ya i was going to get the 2 door but it was 250lbs more then my sedan, it was real nice rally blue with gold rims and 2 doors with the wing and all te goodies. i had one to door back in the day a 323gtx and it was fun but i love my sedans.
CAUTION to any one doing this impreza ej22t swap, give it time to drive the car becuse its like a total diffrent feel of driving it, get used to it before you go crazy it is scary.
Posted: Wed Nov 16, 2005 1:54 am
by bmxpunk
agreed they are a lot of fun though. Mine was quick. then I noticed my friend hadnt completely tightened down one of the intercooler hoses.
I was wondering where all that boost went to. ;)
Posted: Wed Nov 16, 2005 2:23 pm
by snowboarded
Nico, How much did you get the impreza for?
Posted: Wed Nov 16, 2005 9:50 pm
by JC
I didn't read the thread but are you going to swap out the grill and lights for the proper ones?
Posted: Wed Nov 16, 2005 11:35 pm
by NICO
i got the car for 3grand cash, about the head light if i find them in a scrap yard i will get them.
