Page 4 of 28
Posted: Sun Oct 19, 2008 7:02 pm
by TurboBeater
Oh yeah, dyno will be after Stage 2 is done. Will measure stock, Stage 1, Stage 2 all in the same day on the VF11. This is going to be on a mustang dyno.
Posted: Sun Oct 19, 2008 9:57 pm
by RJ93SS
i would only want a bov if it was easy to do, i'm really interested in your chip as i want to run 13-14 psi without fuel cut and without maxing my maf. basically i just want my engine tuned properly for the set up i will have in a few months, including the custom intake i'm desighning and a downpipe. i'll show you more at the meet.
Posted: Mon Oct 20, 2008 2:22 am
by TurboBeater
Custom designed intake and downpipe? Sounds interesting! There's more advantages to a BPV instead of a BOV. The best would be an aftermarket BPV, it should still make plenty of noise. The stock one is actually very noticeable at 17psi!
Got some tuning done today. Ran into a misfire issue above 16psi, gapping the plugs smaller fixed it. Spark and fuel are dialed in up to 5500rpm so far. I measured 0.54G's in 2nd gear! If you check out the first page of this post you can see how much more that is then stock and stage 1 (would be 540 on the chart). Hopefully the dyno numbers follow the same trend that I'm measuring!
Posted: Mon Oct 20, 2008 3:27 am
by RJ93SS
your doing great work man, patiently waiting. just custom intake not custom downpipe. i'll probably find a bellmouth of somesort.
Posted: Sat Oct 25, 2008 7:54 pm
by mexicanzero
cant wait to see stage 2 dyno results!!
i'm in btw.
any chance you guys can do tuning with stock injectors and water/meth injection? i set it up a while back just for the hell of it cuz i got it cheap and want to get the most out of it.
-Alex
Posted: Wed Oct 29, 2008 8:10 am
by asc_up
Gaaaaah. How much longer until Stage 2 comes out?! I waaaaant!!
Posted: Wed Oct 29, 2008 8:11 am
by cj91legss
I know im waiting for it too, and a price estimate... the price may hurt me
Posted: Mon Nov 03, 2008 8:28 pm
by RJ93SS
i checked this out at our meet we had, very cool, here's something you might also be interested to see turbo beater, it could work amazingly well with your chip
http://bbs.legacycentral.org/viewtopic.php?t=34119
maybe we could get the pics updated by josh or whoever
Posted: Mon Nov 03, 2008 9:21 pm
by n2x4
I actually asked about the Select Monitor port back on the first page (I was concerned about it still being able to function), TurboBeater said that they've been using it to help develop the chip, so to answer your question - yep, they've seen it!
Any word on when we can expect the chip to be ready? I'm still surprised we haven't seen the manufacturer post here. Doesn't seem like they're very big and could probably benefit from talking directly to us!
Posted: Tue Nov 04, 2008 5:13 am
by TurboBeater
Yes you're right its not a large company and is a lot of work to run for just a few people. I'm basically representing the manufacturer here as they are busy taking care of the reverse engineering development and daily transactions. I'm also sort of a representative customer too so it works out well.
Status update: Stage 2 power mode for the VF11 is basically complete. Next we're going to lower the octane and tone it down for regular mode. Once that's done its off to the dyno!
Some more good news, I've got a possible source for a 90deg inlet TD05-16g. A VF39 could be in the works too. If the timing is good, these may go on before the VF22.
Yup, we're using the Select Monitor with some in-house developed software to check for knock mainly. The wideband logger has enough inputs to cover the rest.
Posted: Thu Nov 06, 2008 8:12 pm
by 94SS_Canada
Question, How exactly does this "Plug-in" to the ECU? it plugs into it and then you plug your harness into the chip is that correct?
Posted: Thu Nov 06, 2008 8:21 pm
by RJ93SS
i seen it last week, there already a port on your ecu board with a piece of tape over it, you plug it in and your done.
Posted: Thu Nov 06, 2008 8:25 pm
by RJ93SS
turbobeater, when your running at 17 psi, don't the injectors max out. you were saying at the meet you actually leaned fuel out towards redline because it was getting to much. i guess this proves that are injectors can handle it.
Posted: Thu Nov 06, 2008 9:41 pm
by 94SS_Canada
RJ93SS wrote:i seen it last week, there already a port on your ecu board with a piece of tape over it, you plug it in and your done.
Oh, Nice.
Posted: Thu Nov 06, 2008 10:25 pm
by jefferson
Curious at to whether these will be plug in or solder in.
Jeff
Posted: Thu Nov 06, 2008 10:30 pm
by ericem
jefferson wrote:Curious at to whether these will be plug in or solder in.
Jeff
according to the two posts or so above you it will be plug in.
Posted: Thu Nov 06, 2008 10:31 pm
by PhyrraM
Posted: Thu Nov 06, 2008 10:43 pm
by jefferson
Sorry, I didn't realize there were more pages. I didn't read far enough.
Jeff
Posted: Fri Nov 07, 2008 3:09 am
by 93Leg-c
Re-subscribing to this thread . . . hope it works this time. (I subscribed on Oct 19 but haven't been notified of any posts so I finally decided to check it manually . . . )
Posted: Tue Nov 11, 2008 11:37 pm
by jefferson
So how many people have the stage 1 chip? I haven't seen anyone post about what they think of it.
I need to get some other issues sorted on my car and I am there. Going to get a jecs maf to hook up for future stuff.
Lets hear from some people. I can't believe people have bought these chips and said nothing about them.
Jeff
Posted: Wed Nov 12, 2008 2:08 am
by Tommio RS
OMG! This is exactally what im looking for! I need some way to get a safer tune for me Leggy Turbo! I hope you guys figure out way to some STi injectors with a VF39 in the mix! Because thats my route im on right now!
Keep it up men!! Ill buy it as soon as you get a good stage 2 or 3 out!
Posted: Fri Nov 14, 2008 1:08 pm
by DARTHVADER
93forestpearl wrote:Have they done anything with Subaru TCU's?
Check this guy's work.
http://www.alcyone.org.uk/ssm/tcumod.html
I opened my tcu up there are solder dots where a socket can be fitted to allow the use of a DIP-28 style rom.
Posted: Mon Nov 17, 2008 4:46 am
by TurboBeater
So the Stage 2 tune on VF11 turbo is done, I'm going to set up a dyno session this upcoming week. I have the ability to switch between a 14.5 psi and 17 psi tune.
I don't know if anyone else has the Stage 1 tune yet. Maybe they are just waiting for dyno numbers. I think most people are interested in Stage 2 and higher.
Posted: Mon Nov 17, 2008 2:21 pm
by n2x4
TurboBeater wrote:So the Stage 2 tune on VF11 turbo is done, I'm going to set up a dyno session this upcoming week. I have the ability to switch between a 14.5 psi and 17 psi tune.
Wow, awesome to hear. Still confused about 17psi. on a stock VF11. I think I speak for others as well as myself when I say that I'll be down for ordering after I see dyno numbers. Really excited about this!
Posted: Mon Nov 17, 2008 3:08 pm
by kimokalihi
Yeah I thought I read (several times) on this message board that the VF11 is not designed to boost past 13psi and running it that high will shorten it's lifespan a lot.
