07 WRX TMIC & TD05H-16G installation guide
Front, Top, Air, Water.
darkcrave
Re: 07 WRX TMIC & TD05H-16G installation guide
Post by darkcrave »
So basically move the Ftube around and make it fit as best as possible? the TBPS and the coils wires etc. i test fitted the TD05 and it looked like the Intercooling pipe was not even close o.O
Tune
TMIC
Fuel
Taillight
BSOD2600
Post by BSOD2600 »
Yes, move the f-tube so it clears the turbo and intercooler. It doesn't have the stay in the same orientation as OEM -- just as long as the lines go to their correct destinations as OEM.
As stated in the guide, you'll need to modify any Y-tubing you purchase to make it work with any 90* clocked turbo (td04, td05, vf39, etc) and our cars.
'11 WRX Limited
'94 TW | R.I.P.
darkcrave
Post by darkcrave »
What did you do for the coolant line? it was different then the VF11?
Tune
TMIC
Fuel
Taillight
BSOD2600
Post by BSOD2600 »
Coolant lines stayed in the same place.
'11 WRX Limited
'94 TW | R.I.P.
Guttersmash
Post by Guttersmash »
I think this y pipe set up would work, any opinions?
http://cgi.ebay.com/ebaymotors/Top-Moun ... 5ade44bf3c
legacylok
Post by legacylok »
I just installed that exact same kit, it works way better than the Perrin one I had before.
you really can't beat it for the price. but i would recommend getting a slightly longer piece of straight silicone it makes life alot easier .
Kris
92 SS, ej20g, camo wrap, 16g, 06 intercooler,
Robtune, 550s
Dominator
Post by Dominator »
I was looking at that y-pipe kit too, and if you have pictures of it installed to share, that would be great. I was thinking about this one, for a GC8 WRX? I found this style on eBay and it looks like the lower leg to the turbo is longer. That might be able to make up the extra length needed instead of the extra set of clamps and the metal pipe.
Ebay Item number: 300381786957
$110.00 Image
Ebay Item number: 120511544072
$65.00 Image
What do you guys think about that?
Guttersmash
legacylok wrote:I just installed that exact same kit, it works way better than the Perrin one I had before.
just got the kit today and I get what you mean by needing a longer piece. When i bolt the 2 pieces on the the 07 topmount they're offset so the short piece of piping won't really work.
Baddog
Post by Baddog »
What sizes are we talking for the 90 Degree bend and the 2" piece of silicone tubing 2 inch?
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
for the 90 degree bend I think you'll want a 1.75' to 2" reducer. For the 2" piece of silicone, you want 2"........
Baddog
Post by Baddog »
I don't see a 1.75" to 2" reducer. I see the 2.5" to the 1.75" thats about it on silicone intakes.
Thats only if yoire using the vf11 tho. If youre doing the td05 you dont need the 45 degree bend. Sorry, I should have been more accurate.
You just need the 02-05 y pipe kit and a small piece of 2" pipe. And longer piece of 2" silicone.
Baddog
Post by Baddog »
Bought a 2.25" 90 degree bend for the TD04. This is for where it connects to the factory intake. This the right size? Talking about the area circled in red off the turbo.
yes
BoostedSubie
Post by BoostedSubie »
I see someone asked before but have not found any info on anyone trying the silicone y pipe for a GC8 wrx. Whether it would be 93-95 or 96-00? I looked up pictures of a 95-96 jdm wrx and it had the slanty intercooler and uses a similar manifold to the EJ22t so the distance of the throttle body and firewall looks to be the same. So, the distance from the turbo outlet and intercooler inlet would be right on but I have never seen a slanty intercooler to see how the y pipe matches up with it. So the question is, would a silicone y pipe meant for a jdm GC8 wrx work with a 06/07 wrx intercooler on an EJ22t with the TD05? I may have to purchase one to find out if no one else has tried it.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
RckyMtnLegacy
Post by RckyMtnLegacy »
Pics stopped working :(
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
I'd suggest trying send the original post an email or PM to see if he still has the pictures.
RckyMtnLegacy
Did anyone have any luck with this one? Motor is about to go in and I want to be able to put the intercooler in soon too.
http://www.grimmspeed.com/top-mount-int ... it-subaru/
Wtdash and others tried that one. Worked good on the 02-05 tmic, the short silicone piece is horribly kinked on the 06-07. Unless they make an updated one specifically for your tmic i wouldnt bother.
RckyMtnLegacy
Ok thanks
RckyMtnLegacy wrote:Pics stopped working :(
Pics have been fixed.
RckyMtnLegacy
Well this is an exciting day!!
theogt
Post by theogt »
My mount, E85, VF12, Pink STI inj, GT SPEC headler and Prodrive 2.5" exhaust, TMIC WRX 06, new MAP ECU, 4.7V on MAF and 1.18 BAR (17psi), near 200 WHP
