jessmans rio red 91 SS EJ20g swap lots of pics
- Winestone Cowboy
Re: jessmans rio red 91 SS EJ20g swap lots of pics
I'm feeling lucky now, that my swap went smooth with hardly any problems. Good luck bud.
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Well iv got all my rob tune stuff sorted and acquired im just trying desperately to eliminate the knock sensor code and iac code their killing me i cant do it i even went as far as stripping the oem shielded knock sensor wire fully out of a legacy at a scrap yard and used a brand new knock sensor to boot still nothing
the iacv hasn't gotten my full attention yet lol
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
At this point you might have to buy a small gauge shielded wire and run that. I also stripped a junk yard harness, for the cam and crank wires. What a pain in the ass.
mike-tracy wrote:At this point you might have to buy a small gauge shielded wire and run that. I also stripped a junk yard harness, for the cam and crank wires. What a pain in the ass.
Been there, mike isn't lying.
''cracks knuckles'' well its been a while been super super discouraged on my build here i almost sold my car and had it up for sale for a long time i built up and sold a few Honda's on the side while my suby has sat for a long time well its been a year or so and i haven't sold it yet iv gotten it cleaned up a lot more and started fixing all the small things one by one to make me feel better about the car the reason iv been so slow going at this i lost faith in this forum and the friends around me i felt helpless and had nowhere to work on it my self even if i wanted to but enough of that shit i got my momentum back here and wanna finish what i started i don't care how much it cost or how much longer it takes i Have to have this car running good if it kills me iv got a shit load of pics to update ill try and post them chronologically
Do we need some popcorn?
Don't give up, you'll hate yourself in the end.
ok anyways back to some updates i got my down pipe re welded and it worked great i went to wall mart a few months ago to get tires put on a set of oem SS wheels i scored they offered to put the tires on my car for free so i figured why not well they jacked my car up on the down pipe destroying i freaked out they only cut me a $100 check so fuck wallmart from now on i picked up this 02 wrx invidia down pipe a friend of mine he had on his stanced bug eye so he thought destroyed been their done that steal of a deal $20 just needed a bit of work
Wtf....
big thanks to Kimo for the hookup on the rob tune jumper harness setup made things alot easier
got me a set of yellow sti injectors bought the ecu i needed (rob tune 550) and took my intake manifold off for a fourth dam time to sort more wiring
this is getting fairly expensive having to keep buying these new every time i pull the manifold off
got it all back on and together tho and its looking dam good better than one i first swapped it
AND THE FIRST START WITH THE ROB TUNE SETUP
it ran great for about 10 minutes then i went for a drive it kept losing all power and for a while i was stuck at this point
its been a hard road for this car problem after problem but i try to stay confident about it iv gotten this far by my self and with the help you you guys
on a side note i did pick up this momo wrx wheel which im digging alot
flipped another honda and got another and starting the clean the shit out of the sube again she hasn't gotten a proper detail for over a year
