Part number referrence needed
The twin scroll turbo? No, none in the us. We don't have a version 8 or 9 sti, nor do we have a 2.0GT
Anyone know the part # for the little black triangle thingy that covers the screws to attach the mirror?
i can't find it in my parts book.
found them
These are for the black ones. Blue ones are a different part #
94067AA000VG
94067AA010VG
94067AA000VG
94067AA010VG
A friend found Subaru Fast - electronic part catalog for Subaru... ZIP file, 275MB
I installed it, but i cannot get it running; i use WinXP pro,... any ideas how to solve this?
I'll take a look at it, and see what's up.
Well you have to use the clone cd program to burn it to a disc....then you load the program.....however I have not gotten it to work. It keeps giving me a buffer memory error that there's isn't enough memory.
So I don't know. I've tried it on two computers. It looks like this program is setup to run on windows 95, 98, ME....I got an error during install on my 2k machine.
let us know how things work out.
I've tried it in 98....it doesn't work. I've given up....
Dutch friends said this should work... i did't try yet...
Code: Select all
1. Install both of the setup.exe's from the directory cd1 and cd2
2. Copy the contents of both cd's to the folder c:\subaruex (which is the
default folder for the executables from the program)
3. Create a virtual drive with Subst. (go to Start-->Run)
Subst j: c:\subaruex
(you can check if you did this correctly by opening the explorer and see
if there is an J-Drive)
4. Launch Subaru Fast
5. Go to Setup (F3)
6. Set the CDROMDRIVE setting to J
7. Set the other paths to C and point to \SUBARUEX
8. Save Changes via Completion (F12)
9. Now you can use F1 / F2.
To remove the virtual drive:
Go to Start-->Run again.
Subst j: /D
Start Subaru Fast via Start-->Program's-->Subaru Fast-->Subaru Fast. Have you tried it? Does it work?
1993 Legacy
Blue triangle?
Hi Josh,
Do you, by any chance, know the number of the BLUE one for the left hand i.e. driver's door?
Thanks a million in advance.
Best regards
Dusan
[Anyone know the part # for the little black triangle thingy that covers the screws to attach the mirror?
quote="Legacy777"]found them
94067AA000VG
94067AA010VG[/quote]
Best regards
Dusan
94067AA000VG
I'm assuming you want it for the 92-94 MY's.
They are
RH 94067AA000BK
LH 94067AA010BK
They are
RH 94067AA000BK
LH 94067AA010BK
1993 Legacy
part number
Hi,
Thanks a lot! Yes, it is for my 1993 Legacy station wagon.
Best regards
Dusan
Best regards
Dusan
LaureltheQueen
- Spelling Nazi
Code: Select all
5. Go to Setup (F3)
Subst j: /D
Start Subaru Fast via Start-->Program's-->Subaru Fast-->Subaru Fast. Legacy777 wrote:Have you tried it? Does it work?
It works.. perfect - using instructions above... WinXPpro, SP2...
as a few of you may know, i've started working in the parts department at the Subaru dealership here where i live. So, I have access to pretty much every single part including updated and outdated parts ever made by Subaru.... if you have any parts related questions, send me a PM and i'll get back to you with the part number. I've got the net at work, and i check the board every half hour or so on the weekdays, so it shouldnt be a long time before i can get back to you... hope I can help!
Myles
Myles
I've got Subaru Fast 2 - windows edition... works ok with WinXP, SP2....
if anyone has FTP server or knows for a public web server to host files (there are two CDs - one for older (229MB), other for newer models (468MB); i've made two ISO files...) for free - let me know...
For now I've made e-mule (e-donkey) files:
ed2k://|file|SUBARU_FAST2_CD1_OLD_MODELS.ISO|229455872|26D6B3C014ED0E3CC3EC8C1074C0E412|h=QJY5HKE2ZSZZVE2IQAYDK4MPWYETYGI4|/
ed2k://|file|SUBARU_FAST2_CD2_NEW_MODELS.ISO|468959232|46FCFEF76FFEB9E622FE2BAF184DF69E|h=UIAZ5ADXKQY2R5YZ65OHCY6JBLVZ6Q6O|/
screenshot:
http://freeweb.siol.net/odargo/legacy/subaru_fast_2.jpg
screenshot:
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
- quasi-mod-o
Just a little info for you guys...
If any of you wagon owners have broken the little holder clip(s) that keep the cargo cover stretched out... they mount right by the rear window, then you will have a HELL of a time getting the parts guy to understand what you're talking about, and a worse time finding the right diagram.. So the part number for the right side (the left side will be similar) is 65580AA000, and then you have to add the color of your interior to the part number, mine is BK for blue...
I'm posting this, as well as adding the part number to my post on the first page...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Another car, soon to be announced
