CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
Re: CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
cj91legss wrote:Here is how I have my evap set up. It's still only temporary, I will end up not having the canister in the bay. most likely under the battery somewhere.
CJ,
So it looks like the connection points to the canister are the same, and that you've just eliminated some additional purge vacuum lines. The diagram points to a purge valve (item 3), do you have a picture of what that looks like? Is that like the aux. purge valve on the first gen turbo legacy?
Also, I notice you call out a check valve. Was that check valve previously there or was it something that Alphius specifically said to included?
Alphius
Post by Alphius »
OK, here's how I suggested CJ try his purge system:
First, delete the passive valve and extra hoses that go to the turbo inlet like the v7-v8 JDM EJ207 engines have from the factory. This is how I run since I have the rear-mounted charcoal canister just like a WRX. Works fine for me. The purpose of all the extra junk in the WRX system is to use the partial vacuum in the turbo inlet to vent the charcoal canister under boost, and the purge control solenoid to vent under vacuum. What you're doing by deleting the extra valve and hoses is preventing the engine from ingesting fuel vapor from the canister under boost. The purge control valve will still work as factory and pull fuel vapors from the canister under vacuum.
Then, since he has to have his charcoal canister in the engine bay for now, he needs to interrupt the vent line that goes back to the tank and put a canister in line with it.
Now, you have the purge valve connected to the intake manifold, with the other side of the valve connected to the charcoal canister. The charcoal canister is connected to the tank. If the WRX ECU never opens the purge valve under positive boost (I don't think it does, but haven't tested this theory) you'll be fine as-is with no check valve. If at any time the WRX ECU opens the purge valve under boost, you'll have a boost leak into the canister. The check valve is a safeguard against this and should go in the line between the canister and the purge valve, contrary to how CJ drew the diagram up there. It needs to allow the engine to pull from the canister but not allow boost pressure to enter the canister.
In the older cars that "vent" line is directly connected to the tank. The tank vents to the canister in the engine bay, and the engine pulls vapors from the canister.
In the newer cars, the "vent" line is actually the post-canister line since the canister is at the back of the car. The tank vents to the canister, then the engine pulls from that canister through that "vent" line.
We're just taking the engine that's set up for the new style system and modifying it's purge lines to insert a charcoal canister back in the engine bay like the old setup.
Yours looks better Gabe!
I'd just remove everything If I didn't have to deal with fuel vapors in the car. Gabe if the solenoid is removed, can the code be deleted?
Alphius
Post by Alphius »
Yes, the codes can be deleted and you could put a filter on the vent line. Whether you'll smell fuel vapors by doing that is up for debate. Some do, some don't. I've had an open vent line on my Camaro forever and the only fuel smell I get is from the catless exhaust.
Interestingly, I just had to deal with a similar issue on a friend's car that I'm working on. I'm dropping a 99 EJ25D with the new style EVAP system into a 95 Legacy LSi. I interrupted the vent line between the tank and the purge valve and ran it through a charcoal canister. Should work fine. This car did/does have a check valve on the line from the canister to the purge valve from the factory.
Maybe I'll just do that before I finish the tune.
Gabe,
Yeah, that's more or less how my turbo Legacy was setup. I pulled the canister for the time being. I may have a leak or something going on in the rear of the car that I need to look into.
Small report, just enjoying my wrx.
Haven't had much time to mess with anything on the car, but I do have a new garage door installed. I'm very happy with that :-D
Tabs are due, guess the state will take my money so I can be happy. There's an extra 20 bucks on it this year. Its something related to public transportation. Not happy.....
Got a little creative yesterday with my short ram. Turned it into a cold air using some left over piping I had on my shelf. I think it looks pretty decent.
Eventually I will make something to stop water from getting in there. I may just move my license plate over more.
Also having issues with my cigarette lighter plug. Everything interior wise works except it and the clock. Clock itself is damaged, may buy a different clock. Anyways there's no voltage at the lighter harness plug. I've checked every fuse 2-3 times trying to track down why and can't figure it out.
So I had been dealing with some issues getting the car to move from a stop. Once it was moving, it drove fine. It'd bog down a little when you blip the throttle fast but if you eased into it it'd just do what it's supposed to. I would have to bring the rpms up just to get goin at a red light (of course I waited until it was green to actually move.)
Basically I screwed up.
I had a vacuum leak when I had my friend scale my injectors so I could drive it and at the time I didn't know it. Then I did all the work above on the purge control and charcoal canister and fixed said vacuum leak. This was all after the injectors were scaled.
Buddy hooked up his laptop and looked at some stuff. Since the leak was fixed the car was pulling 16-18% extra fuel.
To add to that, I also extended my intake into the fender liner. I also had a pretty dirty maf sensor, I thought I cleaned it good when it got wet from not having a fender liner, I didn't. I only cleaned the air temp sensor.
I learned a lot in the hour and a half I was at my friend's house yesterday.
Don't change anything without planning to tune....
My drive home was so much smoother. Took the wife for a spin and she even noticed how much better the car ran. Got into boost and "holy fuck."
We're not done tuning the car yet either :-D
Haven't gotten much done lately on my car. Other things come up and need to get handled. I'm still driving it tho. Has 3200 miles on it so that's awesome.
I still have to do a boost leak test because I swear I can hear one...
I drove it down to BNW last weekend. Had a little bit of fun with a bug eye on the way, I was a little bit faster ;-). We happened to both stop at the same gas station and exchanged build information. He had a 257 with 205 heads and tuned at 17psi on a td04. He dyno'd at 251whp and 274 wtq.
When I heard that, I got a little excited about my SS
Other than that, nothing else to brag about.
Oh, swapped the whole drivetrain on my wifes car and re timed it. That newer style tensioner does suck.
Changed front mount setups on the whip. Everything looks much nicer under the hood now. I have a wiper washer tank again, something I have not had in 4-5 maybe even more years. Also put the evap canister in the driver's fender area in front of the wheel. Didn't take as many pics as I should have, sorry guys.
Needless to say I like how it is coming along after the last few days.
For that blitz blow off valve, I cut the filter off that plastic fitting bolted to it and JB welded a nipple to it to make it recirculate back into the intake. Nice little mod to a 200+ dollar retail bov!
Btw, this is a 100% GReddy front mount kit. Second kit I've owned in my lifetime. Paid 100 for everything, bov included....
Battery tie down FTW!!!!!!!!!!!!
Alphius
Post by Alphius »
Looks clean! Dealz... ;)
Thanks!
Second kit I came across. First kit was 200. That was 5 years ago.
Drove it all day today. #boost.
And I'm going loud again.
#copmagnet
https://vimeo.com/141294815
Some recent updates Image
Little scratched but that's what happens with used stuff!
I have some more recent goodies to add to this.
Newer steering wheel, seats and glass headlights.
Install time on the lights was about 15-20 minutes. Less than an hour for the seats and maybe 15 minutes for the wheel.
Seats are from a newer impreza, non wrx, but they are definitely nicer that what I had before.
Wheel is 06 wrx.
Headlights, you guys are gonna be mad.... I'm into the pair for 95 bucks.
Sent from my SM-N920T using Tapatalk
dankberries
Post by dankberries »
Lookin good! 8)
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Thanks!
I have other things to add as well but I just don't have the time lately. I have to dig around on here and figure out the electronic leveling and where to put the switch since I don't have the stock dash anymore. The GD center console has the mirror switch in it by the e brake, I think the switch for the headlights would look pretty slick there.
After a bunch of reading, I made the switch to Rotella T6 the oil change before last and I think I'm going to just stick with it. Maybe it's psychological, but I think the engine is a little bit quieter internally.
Other than that, it's got about 8k miles on it, Still haven't finished the tune. It's loud for a daily driver but I've gotten used to to the rumble and my son loves it. Just gotta have the radio louder right?
All in all, I'm very pleased with it, it'll be better whenever I can make it to the tuners house.
Looks really good, CJ!
Thanks!
cj91legss wrote:I have to dig around on here and figure out the electronic leveling and where to put the switch since I don't have the stock dash anymore. The GD center console has the mirror switch in it by the e brake, I think the switch for the headlights would look pretty slick there.
It should be one of these two diagrams.
http://main.experiencetherave.com/subar ... agrams.pdf
http://main.experiencetherave.com/subar ... system.jpg
Thank you josh.
