CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
Re: CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
You're welcome.
When I am devoted to tackling this I was going to print those. I came across them a while back when I was searching for the diagrams.
What's more important, when I have time, is to still get my door locks working. That's actually getting very frustrating having to manually unlock all the doors when necessary. There's still that time factor. With the new job and being tired after work every day, I haven't done much unless it was easy. Things change when your "from shop to shop" time is 10-12+ hours pretty often.
I'm wondering if anyone would be willing to take the time to help me get my front doors lock system working.
I think I have some of it worked out in my head. Not too sure tho.
Sent from my SM-N920T using Tapatalk
I'd have to look at it more closely, but there does appear to be some differences with the actuators and switches. My time is a bit limited right now, but if you don't make any headway on it, shoot me a PM or email as a reminder and I'll try and dig into the wiring.
I wold really appreciate that Josh. I haven't had time myself lately either. I will this weekend and plan to try an attempt at it. Mike is coming by with eerie tho so who knows what progress will come of it lol
Yeah, let me know if you guys take a stab at it.
I have been pretty busy lately chasing down a phantom misfire code. Cyl 4. Recently replaced clutch and flywheel so I'm hoping thats the culprit. Seems that rotational mass changes can freak out the ecu. I.e it's used to the engine rpms decelerating and once you change something that changes that it get's freaked out and CEL. Anyways I'm hoping thats the problem, and I can sleep better. Compression test coming soon as I get up and moving around. Trying to finish my tune before BNW. I may enter it in the car show since I got that fancy dash and all.
Anyways changed my springs out. It's on H&R springs now.
And some Hoodless porn
Pntaste4evr99
- Winestone Cowboy
I was planning on going to BNW this year, I'll enter the show if anyone wants to join with me, only $60 to enter. Be cool CJ if u wanna? 2 first gens, hopefully more?
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
Cylinder 4 low compression. Car isn't going...
Pntaste4evr99
- Winestone Cowboy
How low? Drivable low, or dead hole low?
65 psi.
Pntaste4evr99
- Winestone Cowboy
That sucks man, sorry to hear.
Sounds like you may have blowed up a piston.
We'll see, I'm going to pressurize the cylinder here in a bit and see what I hear. All in all, motor is probably coming out and getting torn apart again.
meatball671
I had the same thing happen to me with the misfire, but I still had high compression, it was kind of a freak thing because the code just went away by itself. Stupid Cyl.4 lol
Sent from my SM-G900V using Tapatalk
Jonah
92 legacy wagon N/A 5MT
93 legacy sedan 25th anniversary edition 02 wrx swap ver 2 jdm 5MT
93 legacy TW 25th anniversary edition 4EAT stock with supporting mods
94 legacy TW 4EAT built ej22t vf-34 CES exhuast
I guess I should leave some sort of an update. Some of you probably know already because of the constant bitching I've done about the issue on facebook.
Broken ringland on the #4 piston. It sucks BUT hardly any damage to the cylinder wall SO light hone and go.
I'm going to be experimenting with some 22E pistons. I have a different set of 205 heads now that have ZERO spark plug cracks but had some bent valves, I'm swapping my valve train over and the cool thing is this set of heads even came with solid lifters vs the shim over bucket I had.
So I'm lapping valves, never done it before but what ever, there's a first time for everything. To add to that, I've never done rings or honed a cylinder before either. Yay!
Fortunately I have a bad 22e to practice on!
Anyways here's some pics...
You can see the old bent valves in the back!
Sad times...
Oh and btw, remember that god damn boost leak I was looking for but could never find? Back seal between the compressor housing and the backing plate.... Asshole turbo nearly made m lose my mind. That's all sealed up now tho.
Sad times...
That sucks.....but it sounds like you're making progress.
Eh not really. Haven't been motivated with it lately, so my garage still looks the same.
I think we've all been there. Take a break from it and come back when you feel like working on it again.
Good advice. Forget about it for a while. Your desire to mess with it will return eventually. I'm so burnt out on working on my stupid metro lately. I don't have much choice, unfortunately. I have to drive the stupid thing to work.
Well after a while from it I have started pushing myself to get back into this thing. Some of you have already seen pics on FB. I dropped my case halves off yesterday morning for a bore/hone for wiseco 97.5mm pistons. Downside is they say 2 weeks out, they have a bunch of subaru engines from PIA that they have to work on too....
Gonna do some more valve work on this RH head because I can see some spots on the seat that need to go away.
New set of case bolts can be had for 60 bucks so that's the route im going, gonna go with cometic gaskets again, OH AND F***KING TUNE THIS TIME.....
Sorry about that, rant over.
Pntaste4evr99
- Winestone Cowboy
Just grab another motor from Mike, drop it in till yours is back together, he only has like 15 or so in his garage lol
I've got a few too lol.
I'm just gonna build the block and hopefully be done for a while. Or at least until transmission #5 goes out.
Pntaste4evr99
- Winestone Cowboy
There are 6 speeds around to put in, be done with it. That is if u have the spare cash for one.
You break enough 5-speeds that it sounds like a 6-speed would be worth it...
