high idle saga continues.....(little long)
Posted: Thu Apr 18, 2002 7:34 pm
Not sure if I posted on here, my initial problems........here's a quick run down.
Two weekends ago I ran a 4 step cleaner shit through my engine. First part goes in the fuel, second part get's sucked in to the intake through vacuum, third part goes in the oil, (what I was told was that it is likes vicks vapor rub for your engine....cleaning pcv system and such. Fourth part is a throttle body spray......nothing really different then throttle body cleaner.
Well after I had gotten done spraying the throttle body cleaner in the intake.....and cleaning all the carbon away from the butterfly and such......my idle was quite a bit higher......1100-1300 rpm when in neutral or park. When I put it in gear, idle drops to about 800 or so....but I've gotta hold my foot on the brake a lot more steady......or the car will just start idling away due to the high idle.
Since the initial problem.....Here's a couple things I've noted and noticed while trying to diagnose.
When the car is cold in the morning....it starts normally....idle jumps up to around 2000, then calms back down to normal high idle speed. If I give it some gas....and get the idle to bump back down.....it'll come down to almost normal....about 800 or so.....when in neutral or park.
Other thing it does....and sorta has been doing for some time. If I start it up.....and don't let it warm up for a while......put it in gear and go to accelerate, the idle drops....car sputters and putts for a couple seconds......then idle kicks back up to normal high idle. If I don't touch the gas, and put it in gear and let it coast away.....it doesn't do it.....only when I touch the gas, and when it is "cold" It has done this for a while....like 4 years or so....it had seemed to be more pronounced if I ran premium fuel. I normally run mid-grade, 89.
Some of the stuff I've done to try and trouble shoot. I've tried sprayin throttle body cleaner and such around the engine....to look for air leaks....none seemed to surface....
I've disconnected the plug from the IAC valve, and idle jumps up and is really rough.
I've also taken the top electronic piece off, and manual controlled the rotary valve....didn't seem to bring back into check to well either.
Latest thing I've done is taken the air intake goin into the IAC valve off the intake arm and see what happens......idle drops a little bit....like 100 rpm....but nothing much........I then plugged the IAC valve hose......again....a tad lower then when it's normally hooked up....but not back to normal.
The one weird thing was......when I got it plugged up, and go to start the car......the idle will jump to about 1000, then settle to where it should be....stay there for a couple seconds then just kick back up to 1000-1100 rpm........it's like it's working fine....then ECU is getting signal for something, and tries to correct something that shouldn't be.
I have/had been pretty animate about the IAC valve being bad. There is actually two portions to it (for the AT models only). There is an electromagnet portion that fine tunes the idle with a rotary valve type thing. The other portion is a bimetallic strip that is hooked up to the lower portion of the valve.....it has coolant lines running to it.....as coolant heats up....it will close another valve before the rotary valve to cut the air off.
Haynes says this thing should be completely closed when the car is hot. Only thing is I don't think it's "totally" closed.....or the electronic portion wouldn't serve a function.....but there's a longer portion where I think it closes......I believe this is also working properly....probed a screw driver in there to feel where the valve was.
I've tested the electronic portion according to the manual, and everything checks out.
I just picked up a IAC valve off of a 94 motor......I was goin to try and swap it in......it looks in so-so shape....only reason I'm hesitant is because there is rust inside the portion where the coolant lines go.....I don't really want that stuff in my cooling system.
I'm starting to question whether it is actually the valve or not......because I plugged it.......and it still had a high idle......
I've played around with a new TPS too.....however I've since put the old one back on.....and put it exactly where it used to be......I've even re-adjusted it back to specs....according to the Haynes manual.
I've got some brake cleaner, and actual carb & choke cleaner which I may try and use to search for vacuum leaks.
Do you think any of the cleaner stuff fubared the O2 sensor.....or anything else......I just can't see what would cause such a problem......only thing I can think of is there was gunk somewhere......that was blocking a leak or something.....now it's not there.........
I really want to get this fixed........I need some feedback on what others think.
Really appreciate it.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
of beats and rhythm" - ME
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1994012.34 ... ?code=3466> Click Here!
<http://us.adserver.yahoo.com/l?M=194081 ... =353948236>
Josh Colombo
ADVERTISEMENT
