Ben's EJ20 Swap
Locked
William D. Robinson
Ben's EJ20 Swap
Post by William D. Robinson »
Ben:
Since the stock fuel pump is one of the first weak links to reveal itself in turning up the wick on an EJ22T, I would assume that it would also be the first weak link to pop its head up when trying to sort out an EJ20. I would guess that a Walbro pump would be a good start. You might not need a rising rate piggyback fuel pressure regulator, as the stock regulator oin an EJ20G and EJ22T are identical and the EJ20G has bigger injectors. I think the rising rate fuel regulator is primarily to squeeze a bit more spray out of the wimpy EJ22T injectors.
Hey Mark Ward, can you tell us exactly which extra two wires we will need?
Bill Robinson
ADVERTISEMENT
<http://rd.yahoo.com/M=217097.2003762.34 ... ge=account>
<http://us.adserver.yahoo.com/l?M=217097 ... =351759071>
Brett Middleton
Ben's EJ20 Swap
Post by Brett Middleton »
do you realise all EJ20's already have rising rate fuel pressure regs?
Brett Middleton
MRT Performance
We Rally, You Win.
www.MRTrally.com.au <http://www.mrtrally.com.au/> main pages
www.ECUtek.com.au <http://www.mrtrally.com.au/shop> Tune your Subaru
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Sent: Saturday, 20 April 2002 50 PM
Subject: [BC-BFLegacyWorks] RE: Ben's EJ20 Swap
Ben:
Bill Robinson
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=217097 ... =908885833>
ej22t
Ben's EJ20 Swap
Post by ej22t »
Could you tell me more about it, since I don't even understand on
this !!
Ben
regs?
> Brett Middleton
> MRT Performance
> We Rally, You Win.
Subaru
> From: William D. Robinson [mailto:vultureboy@m...]
> To: BC-BFLegacyWorks@y...
> Ben:
itself in
be the
EJ20. I would
a rising
an EJ20G
think the
out of
will need?
> Bill Robinson
> ADVERTISEMENT
<http://rd.yahoo.com/M=217097.2003762.34 ... upweb/S=17
050649
> 83:HM/A=1042587/R=0/*http://service.bfast.com/bfast/click?
bfmid=29150849&sit
> eid=39282504&bfpage=account>
M=217097.2003762.3481930.1261774/D=egroupmai
> l/S=1705064983:HM/A=1042587/rand=351759071>
> BC-BFLegacyWorks-unsubscribe@e...
> zZz
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/orkH0C/n97DAA ... /XoTolB/TM
jason grahn
Ben's EJ20 Swap
Post by jason grahn »
A rising rate fuel pressure regulator (RRFPR) increases fuel pressure with
every extra PSI of boost you run. Some regulators are setup in a 4:1 ratio
some (extreme case here) are 12:1.
The ratio (4:1 for example) relates an increase for 4 psi of fuel pressure
for every 1 psi increase in air pressure. This makes sure that enough fuel
is given to the engine.
I prefer fuel tuning to be done by a big fuel pump, precise injectors, and a
kick ass aftermarket ECU; rather then this system. While more expensive,
it's more efficient.
-Jason
>this !!
>Ben
Join the world’s largest e-mail service with MSN Hotmail.
http://www.hotmail.com
Buy Stock for $4
and no minimums.
FREE Money 2002.
Mark Ward
Ben's EJ20 Swap
Post by Mark Ward »
The stock wiring harness has 2 wires for the ignition coil, the EJ20 ECU has 4 wires for the coil packs. There is spot for the wires on either side of the 2 EJ22 wires.
Mark
Ben:
Bill Robinson
milehial2000
Ben's EJ20 Swap
Post by milehial2000 »
Anyone know where a EJ20 ECU might be obtained? I am working on a EJ22
t with dual cam heads and running 26lbs of boost. The lobes for the
exhaust valves are staggered as to timing to start a stir of the
incoming charge and this stir is blowing the spark out and giving a
misfire code on occasions and we might want to try the quad coil
setup for a little healthier spark. Right now we are running it with a
'98 ECU.
ECU has
side of
> the 2 EJ22 wires.
> Mark
> Ben:
reveal
would also
EJ20.
not need
regulator oin
I
more
will
> need?
> Bill Robinson
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> ADVERTISEMENT
Service.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
I am still using the stock pressure reg on my EJ22t but went with
the Walbro because what we found was that when you get to a certain
point with these motors it gets to be a matter of volume. The stock
pump just can't handle it and pressure will drop at the high end. But
sometimes a better regulator will be needed because of high boost
fighting fuel pressure.
AL(CO)
regs?
> Brett Middleton
> MRT Performance
> We Rally, You Win.
Subaru
> Ben:
itself in
be the
I would
a rising
an EJ20G
the
out of
need?
> Bill Robinson
> ADVERTISEMENT
050649
83:HM/A=1042587/R=0/*http://service.bfast.com/bfast/click?bfmid=291508
49&sit
<http://us.adserver.yahoo.com/l?M=217097 ... 1774/D=egr
oupmai
> zZz
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Josh Colombo
Ben's EJ20 Swap
Post by Josh Colombo »
Al,
have you considered, or tried running an MSD II ignition unit.....since you're talking about the 98....it probably has the updated coil pack to make use of the higher ignition source.
I know Dave has one setup on his TW......may be worth a try as trying to find an EJ20 ECU might be a little tough.....
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Tue 4/23/2002 80 AM
Cc:
Subject: [BC-BFLegacyWorks] Re: Ben's EJ20 Swap
'98 ECU.
ECU has
side of
> the 2 EJ22 wires.
> Mark
> Ben:
reveal
would also
EJ20.
not need
regulator oin
I
more
will
> need?
> Bill Robinson
Service.
> ADVERTISEMENT
Service.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
ya, we thought about it this car belongs to a engineer in Montana and
he is pretty sharp and wonders with the high RPM (over 8000) this
thing is turning if there would be enough time for the multi-spark
system to operate correctly there is a limit to everything. Anyone
know about this or have opinions? I always have had pretty good luck
with the stock ignition but I am not going as far with this as he is.
AL(CO)
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Al,
> Josh
> From: milehial2000 [mailto:acroxford@h...]
> Cc:
on a EJ22
for the
the
giving a
coil
it with a
> '98 ECU.
the EJ20
> ECU has
either
> side of
> > the 2 EJ22 wires.
> > Mark
> > Ben:
to
> reveal
that it
> would also
sort out an
> EJ20.
might
> not need
stock
> regulator oin
injectors.
> I
a bit
> more
wires we
> will
> > need?
> > Bill Robinson
of
> Service.
> > ADVERTISEMENT
of
> Service.
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
Samuel Barrett
Ben's EJ20 Swap
Post by Samuel Barrett »
How much HP is this thing pushing?!
-Sambo
Sent: Tuesday, April 23, 2002 60 AM
'98 ECU.
ECU has
side of
> the 2 EJ22 wires.
> Mark
> Ben:
reveal
would also
EJ20.
not need
regulator oin
I
more
will
> need?
> Bill Robinson
Service.
> ADVERTISEMENT
Service.
Buy Stock for $4
and no minimums.
FREE Money 2002.
nickson brad
Ben's EJ20 Swap
Post by nickson brad »
Im running a quad coil setup on my 93 RS cause the
standard coils wouldnt fit inside the updated heads i
put on, its works fine.. using bosch HEC716 coil pack
and 8mm high energy leads..
George
> -Sambo
> working on a EJ22
> The lobes for the
> stir of the
> out and giving a
> the quad coil
> running it with a
> '98 ECU.
> ECU has
> wires on either
> side of
> > the 2 EJ22 wires.
> > Mark
> Swap
> > Ben:
> weak links to
> reveal
> assume that it
> would also
> EJ20.
> start. You might
> not need
> as the stock
> regulator oin
> bigger injectors.
> I
> to squeeze a bit
> more
> extra two wires we
> will
> > need?
> > Bill Robinson
> email to:
> Yahoo! Terms of
> Service.
> > ADVERTISEMENT
> email to:
> Yahoo! Terms of
> Service.
> to:
Do You Yahoo!?
Yahoo! Games - play chess, backgammon, pool and more
http://games.yahoo.com/
Buy Stock for $4
and no minimums.
FREE Money 2002.
nickson brad
Ben's EJ20 Swap
Hi..im running a quad coil setup on my 93 RS cause the
George
> -Sambo
> working on a EJ22
> The lobes for the
> stir of the
> out and giving a
> the quad coil
> running it with a
> '98 ECU.
> ECU has
> wires on either
> side of
> > the 2 EJ22 wires.
> > Mark
> Swap
> > Ben:
> weak links to
> reveal
> assume that it
> would also
> EJ20.
> start. You might
> not need
> as the stock
> regulator oin
> bigger injectors.
> I
> to squeeze a bit
> more
> extra two wires we
> will
> > need?
> > Bill Robinson
> email to:
> Yahoo! Terms of
> Service.
> > ADVERTISEMENT
> email to:
> Yahoo! Terms of
> Service.
> to:
Do You Yahoo!?
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
Lots we haven't dynoed it yet will let you know when we do. The most
we have gotten out of a EJ22t other than this one was on the dyno
at 318hp it was also running 26lbs boost but that was with stock
heads.
AL(CO)
> -Sambo
EJ22
a
> '98 ECU.
EJ20
> ECU has
> side of
> > the 2 EJ22 wires.
> > Mark
> > Ben:
> reveal
> would also
an
> EJ20.
> not need
> regulator oin
injectors.
> I
> more
we
> will
> > need?
> > Bill Robinson
> Service.
> > ADVERTISEMENT
> Service.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
He checked on the MSD II today I guess that it only has multiple spark
up to 3000 rpm then it switches to conventional spark.
AL(CO)
> Al,
> Josh
> Cc:
on a EJ22
for the
the
giving a
coil
it with a
> '98 ECU.
the EJ20
> ECU has
either
> side of
> > the 2 EJ22 wires.
> > Mark
> > Ben:
to
> reveal
that it
> would also
sort out an
> EJ20.
might
> not need
stock
> regulator oin
injectors.
> I
a bit
> more
wires we
> will
> > need?
> > Bill Robinson
of
> Service.
> > ADVERTISEMENT
of
> Service.
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
Ben's EJ20 Swap
I know these units are supposed to be good....but i guess I don't fully understand what they do. What exactly does the multiple spark function do?
Sent: Tue 4/23/2002 11:19 PM
Cc:
AL(CO)
> Al,
> Josh
> Cc:
on a EJ22
for the
the
giving a
coil
it with a
> '98 ECU.
the EJ20
> ECU has
either
> side of
> > the 2 EJ22 wires.
> > Mark
> > Ben:
to
> reveal
that it
> would also
sort out an
> EJ20.
might
> not need
stock
> regulator oin
injectors.
> I
a bit
> more
wires we
> will
> > need?
> > Bill Robinson
of
> Service.
> > ADVERTISEMENT
of
> Service.
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
>From what I get is that with blowers,turbo's, wild cams, and high
compression the spark can be blown out and the multiple spark high
energy ignition units supply a good hot spark and additionally give
several sparks rapidly during the allowable time to keep timing close.
This is just in case the first spark is blown out or fails to ignite
the charge.
AL(CO)
function do?
> Cc:
multiple spark
> AL(CO)
wrote:
> > Al,
the
as
> > Josh
> > Cc:
working
> on a EJ22
lobes
> for the
stir of
> the
and
> giving a
quad
> coil
running
> it with a
> > '98 ECU.
ignition coil,
> the EJ20
> > ECU has
wires on
> either
> > side of
> > > the 2 EJ22 wires.
> > > Mark
> > > Ben:
weak links
> to
> > reveal
assume
> that it
> > would also
trying to
> sort out an
> > EJ20.
start. You
> might
> > not need
the
> stock
> > regulator oin
bigger
> injectors.
> > I
squeeze
> a bit
> > more
extra two
> wires we
> > will
> > > need?
> > > Bill Robinson
email to:
Yahoo! Terms
> of
> > Service.
> > > ADVERTISEMENT
email to:
Terms
> of
> > Service.
> > Buy Stock for $4
> > and no minimums.
> > FREE Money 2002.
to:
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
Josh Colombo
Ben's EJ20 Swap
Why would it not be continued past 3000 rpm......lack of time between sparks as RPM increases......
Sent: Wed 4/24/2002 9:49 AM
Cc:
the charge.
AL(CO)
function do?
> Cc:
multiple spark
> AL(CO)
wrote:
> > Al,
the
as
> > Josh
> > Cc:
working
> on a EJ22
lobes
> for the
stir of
> the
and
> giving a
quad
> coil
running
> it with a
> > '98 ECU.
ignition coil,
> the EJ20
> > ECU has
wires on
> either
> > side of
> > > the 2 EJ22 wires.
> > > Mark
> > > Ben:
weak links
> to
> > reveal
assume
> that it
> > would also
trying to
> sort out an
> > EJ20.
start. You
> might
> > not need
the
> stock
> > regulator oin
bigger
> injectors.
> > I
squeeze
> a bit
> > more
extra two
> wires we
> > will
> > > need?
> > > Bill Robinson
email to:
Yahoo! Terms
> of
> > Service.
> > > ADVERTISEMENT
email to:
Terms
> of
> > Service.
> > Buy Stock for $4
> > and no minimums.
> > FREE Money 2002.
to:
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
milehial2000
Ben's EJ20 Swap
I am not sure possibly there is not enough time to get more than one
spark when the RPM gets that high. This is just what he told me about
the MSDII unit.
AL(CO)
> Cc:
high
high
give
timing close.
ignite
> the charge.
> AL(CO)
don't
spark
> function do?
> > Cc:
has
> multiple spark
> > AL(CO)
<josh@s...>
> wrote:
> > > Al,
ignition
probably has
> the
source.
worth a try
> as
tough.....
> > > Josh
> > > Cc:
Swap
obtained? I am
> working
> > on a EJ22
boost. The
> lobes
> > for the
start a
> stir of
> > the
spark out
> and
> > giving a
try the
> quad
> > coil
we are
> running
> > it with a
> > > '98 ECU.
<mark@r...>
> ignition coil,
> > the EJ20
> > > ECU has
for the
> wires on
> > either
> > > side of
> > > > the 2 EJ22 wires.
> > > > Mark
EJ20 Swap
> > > > Ben:
first
> weak links
> > to
> > > reveal
would
> assume
> > that it
> > > would also
when
> trying to
> > sort out an
> > > EJ20.
good
> start. You
> > might
> > > not need
regulator, as
> the
> > stock
> > > regulator oin
EJ20G has
> bigger
> > injectors.
> > > I
primarily to
> squeeze
> > a bit
> > > more
which
> extra two
> > wires we
> > > will
> > > > need?
> > > > Bill Robinson
send an
> email to:
the
> Yahoo! Terms
> > of
> > > Service.
> > > > ADVERTISEMENT
send an
> email to:
the Yahoo!
> Terms
> > of
> > > Service.
> > > Buy Stock for $4
> > > and no minimums.
> > > FREE Money 2002.
email
> to:
> > Buy Stock for $4
> > and no minimums.
> > FREE Money 2002.
to:
> Buy Stock for $4
> and no minimums.
> FREE Money 2002.
Buy Stock for $4
and no minimums.
FREE Money 2002.
Locked
