Blitz boost controler
Posted: Sun May 18, 2003 1:26 am
by subiekid
hey, i am gona get the blitz electronic boost controler. but i do not know if i should get the single of double solenoid? what is the difference? it says the single will have faster boost.
Posted: Fri May 23, 2003 5:14 am
by Nate S
From what I can see the difference being the dual solenoid can handle the higher boost settings, most likley an internal stretch or valving design difference. If you are going to run lower boost levels ( IE under 20 psi ) the single ought to be fine for you.
Nate
Posted: Fri May 23, 2003 3:04 pm
I don't know about the Blitz controllers specifically, but a lot of the time dual solenoids allow electronic boost controllers to get more precise control, because rather than having two options (open and closed) they have three (open, half open, closed). As with any EBC, though, it depends heavily on how good the programmers who built the controller were.
