and to add insult to injury, H&R lists a spring for all 90-98 Leagcy's, AWD, except wagons! How am I to even start guessing which will actually fit the car?
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Leacgy suspension (again)
Adam,
First off I can tell ya I have talked with Dale Teague and has tried H&R springs......couldn't get a correct fitment......If you can get spring rates from them, I think you could do a little comparing to what I posted on i-club about the stock spring rates and see if they would produce results you would like.
As for the fitment of struts, springs etc. Here it goes.....everything that I know as of now.
90-94 front struts/springs on all legacies, AWD/FWD, auto/manual, turbo/non-turbo are interchangeable. They will fit and are swapable. I believe even some of the newer springs/struts from the second gen would physically fit as well. The only issue would be spring rates.....AWD/FWD rates are goin to be different as well as turbo/non-turbo.
Rears.....now that's where everything get's mucked up.
1990-1991 rear springs are tapered at the top compared to the 1992+ models. Inner diameter of the top portion of the 90-91 rear springs is about 90mm. The bottom portion is about 138mm ID. The 1992-1994 models the rear springs, the inner diameter of the top is about 120mm, bottom portion is about 140mm ID.
The question I have is, can we just get a top mount from a 92-94 legacy and fit it in the 90-91 legacy? That is the $100 question. I'm hoping ciper can answer this. Adam I think he was goin to contact you about getting the sti top mounts, and giving them a shot? If that works, then we know the wider top mounts will fit up in there and you can use the fatter springs from 92-94.
Struts, there's three main things about the struts. The mounting location (comes into play for AWD/FWD), body height of the strut (again comes into play with AWD/FWD, and possibly sedan/wagon), and finally perch location, i.e. how far up the body of the strut is the perch mounted.
The mounting location onto the car. The AWD cars have the mounting location of the strut onto the spindle set back a little bit from the axle. It is also raised up slightly. By how much.....I'm not exactly sure.
Body height of the strut. I have been told from Dale Teague that the body of the AWD rear struts vs. the FWD rear struts is shorter. I don't think this really is an issue with sedan vs. wagon....but it's possible.
Perch location, the whiteline rep mentioned this and it make sense, if it is raised or lowered in comparison to the stock struts or wagon vs sedan.....you could be ultimately lowering the rear end or jacking it up.
What my theory or "HOPE" is.....Since the rear strut for the FWD cars is a tad longer then the rear strut for the AWD cars......."AND" the mounting location for the FWD cars is lower then the mounting location for the AWD cars that the difference surrounding the two will be negated and the strut perch will sit at the same position or height.......this is assuming the perch is mounted at the same spot.....relative to the top of the strut.
If this works out......and ciper finds out that the sti top mounts do fit in the rear of the 90-91 models.....I could get the wider springs for my car....and sti top mounts. Same goes for you too Adam. That would mean you would be able to fit stuff for a 92 legacy turbo wagon onto your 91.
So everything is hinging on what ciper finds out....hehehe
Hope this helps things.....sorry for my steer towards my FWD oddity subie
-----Original Message-----
Sent: Wed 7/10/2002 1:48 PM
To: bc-bflegacyworks@yahoogroups.com
Cc:
Subject: [BC-BFLegacyWorks] Leacgy suspension (again)
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Cc:
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Josh - thanks
Well here is what KYB told me today - everything apparantly does interchange betweent he 91 and 92 models, including stur mounts. This is reinforced by the fact that Tein lists front and rear pillowball munts (to be added as an option to their coilovers kits that don't already include them) for the BC5 and GC6/8 models...both have the same part number. Again, this is sorta telling me that the mounts are interchangeable. BUT, the spring seats are different diameters (which we knew already), and the sturts themselves are different lenghts. I had asked about installing AGX's - he said they will bolt in, provided I ahve the rear mounts, but the fronts would raise the car about 1/2 inch, the rear would drop the car about 1/4 inch....not the effect I am looking for!
So, I have the rear STi mounts comin in (need to get some fronts here quickly too), and just ordered the Tein S Techs today for a GC8..spring rates are 179 lbs. front and rear, so I am hoping this will be a good match. Rather than throw it all away, I am going to stick with GR2's...afterall, this is not going to turn into a project car/money pit
...I already wn 2 of those in my ZX and Galant VR4, both of which are modded to the hilt!
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Lemme ask ya this Adam and everyone. It does sound like the struts are not interchangeable from what KYB is saying.....and I too will just have to keep the GR2's and hope they have enough guts to keep the whitelines in check.
Going off of what the Whiteline rep had said about the two sets of springs having pretty much the same compressed height......I'm still curious to if the wider top mounts will fit in the 90-91 fenderwells. Is there any chance you can check on this when you get them? Or is there possibly a different top mount for the 90-91 models?
Do you think the sti top mounts are even worth the hassles I'm tryin to go through to get them? What about putting just the fronts in? Or would that produce weird suspension setup. I learned my lesson about putting different type of struts on the front and rear.....not good in achieving a balanced car.
What do ya think? comments....questions.....am I crazy???
All to be answered tonight on nightline!
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
of beats and rhythm" - ME
Sent: Wednesday, July 10, 2002 3:49 PM
Subject: Re: [BC-BFLegacyWorks] Leacgy suspension (again)
Josh - thanks
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
{short description of image} <http://us.a1.yimg.com/us.yimg.com/a/de/ ... 0north.gif>
Josh Colombo
Josh - thanks
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Well, I don't think top mounts in the front only or rear only will upset things..i jsut figured that as long as the stock ones are coming out for the sturt/springs, and there are better ones offered, there are worse things to install after 159k miles!
We can get the strut mounts easily BTW..I do not think there are Legacy specific ones, but rather the BC and GC chassis cars use the same ones AFAIK
I have always had good luck with the GR2 BTW - they are not an OE replacement strut BTW, but rather about 20% stiffer than stock..I ahve had them on just about every car I have done that didn't get coilvovers
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Can you check your books and see if you can get sti top mounts specific for the 90-91 legacies for their narrower rear springs? Pretty much.....if they work on your car......they should work on mine, because you have the narrower springs correct? Or are you putting the wider spring on and using the top mounts that go with that?
Yeah....I have no real complaints with my GR2's. I have been surprisingly pleased with their performance. I've got about 55,000 miles on them. I'm sure they prob don't wear out as soon as OEM struts.....but what sort of mileage have you gotten on them?
Thanks man
Josh Colombo
Sent: Wednesday, July 10, 2002 5:12 PM
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Thanks man
Josh Colombo
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Well, I have 59,000 on my GVR4 now with them, but am going with tein HA's shortly (been in my basement for about a year, figure its about time!)
There is no Sti mount for the 91 model car...I am going to use the GC8 ones, and got Tein springs for a GC8 as well....all "should" work, we'll know next week I guess
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Do the tein springs have the wider top portion for the rear springs? I would assume so correct? Has ciper contacted you about getting the sti top mounts for his car? I am curious to know if they physically fit up in the fenderwell.
what could you do for me......how much for 4 new GR2's for my car....90 Legacy FWD......Also can you buy just the front sti top mounts.....or do you have to buy all four? Same question about cost?
Josh Colombo
Sent: Wednesday, July 10, 2002 5:53 PM
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
<http://rd.yahoo.com/M=229641.2166546.36 ... debtscape/>
Josh Colombo
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Josh - yes, Impreza (GC8) spings are pretty wide in the rear.
I am 99% positive the mounts bolt right in (ciper didn't contact me yet though)..again, this comes from Tein telling me that the pillowball mounts they sell for a BC5 and GC8 are the same part number, and further by the telling me any GC8 coilover they offer fits in the Legacy too, but you need pillowball mounts if not already part of the kit (for example, Tein HA des not come with the pillowballs, they are optional).
You can buy just front monts, or front and rear as a pair...fronts are not the problem though, rears are. I don't ahve the prices in front of me, but I can post tomorrow....you'll find we are more than competitive though on all Sti stuff.
GR2 4 new ones would run you $270.00 plus shipping
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
