Fuel pump discussion
Posted: Wed Jul 17, 2002 9:00 am
by Rabin Rutten-James
Hi all
Mark wrote:
I think you have bigger issues. there is something wrong somewhere else. If
John had similar problems there is more then your mods to deal with. I have
never heard of anything like this. Byron has suggested checking your
cylinder heads to make sure they are straight, and to make sure the new
exhast manifolds are straight. they should match up nicely before bolting
tight.
The new stuff went on perfectly, and everything was OEM. All the exhaust
pieces lined up, factory steel gaskets used - hell even the bolts to bolt it
all together were all dealer supplied!
What I dont understand and never have is why you need the custom shaped
gasket on a stock exhaust system (at least till the turbo...)
The only reason for the custom gasket was the warpage of the manifold in the
first place. Initially we thought it was alignment problems since the
furthest thing from our minds was that a cast manifold had warped. This was
confirmed when the new manifold arrived. The gap to the up-pipe was nearly
1.5" at it's wides point
I figured the reason was a poorly designed manifold, but nobody else has
ever had the problem. Makes me wonder what the heck to do about it.
Timing and fuel pump are the biggest leads...
Rabin
Posted: Wed Jul 17, 2002 6:00 pm
by INCEv@webtv.net
"Warped exhaust manifolds" Sounds like cold water coming in contact!
$.02 Dan
