Are there any special procedures on bleeding the brakes on a sport sedan that would be different from other cars out there… a quick reply would be appreciated.
John Dolinga
Bleeding the brakes
Josh Colombo
Bleeding the brakes
Service manual say bleed in this order
Front right
Rear left
Front left
Rear right
Some have said if you are completing flushing the system, you want to do the longer run first, in that case you would do
Rear left
Front right
Rear right
Front left
Front right
Rear left
Front left
Rear right
Rear left
Front right
Rear right
Front left
