door speakers mounting depth
Posted: Sat Jul 27, 2002 1:57 am
by John D
What’s the max mounting depth for speakers in the doors for 90-94 legacy
John Dolinga
www.SunnyGulf.com
Posted: Tue Jul 30, 2002 3:09 pm
by John D
Where can I get spacers at? Or did you make them?
John Dolinga
www.SunnyGulf.com
Posted: Tue Jul 30, 2002 3:10 pm
by Josh Colombo
You will almost definitely need speaker spacers to put any speakers in. The speaker will hit the window when it's down if you don't do this. I have Infinity Kappa 63i's in my front doors. Had to do some persuading, but I have 1" speaker spacers, and it works.
Posted: Thu Aug 01, 2002 2:55 am
by Josh Colombo
Well......the first set I bought. The second set I had to make. The tweeter portion of the kappas came off of the first set of speakers after like 2 years......sent them back to infinity, they sent me a new updated pair. Well the new ones were a tad deeper, so used some marine plywood and made spacers. I've got some pics on my site
www.surrealmirage.com/subaru
Posted: Thu Aug 01, 2002 3:46 am
by Douglas Hancock
I’ve got some pioneer splits in the front of mine. I used the 3 hole setup and only needed to pack out the bottom two holes. You should make your own spaces out of some dense timber ie MDF, ply for the best sound. If you use plastic it will sound like plastic.
Posted: Fri Aug 02, 2002 4:10 am
by INCEv@webtv.net
I took the old front speakers and drilled the spot welds and mounted the
new ones on the old plates. $.02 Dan
