Error codes
Posted: Sat Aug 10, 2002 10:02 pm
Hi
When checking the error codes and no code is found what should
the 'check engine' light do? Is it steady on, flashing or off?
Also if using the green T wires D-check procedure how far can the car
be driven with the green T wires coinnected to check for faults?
Reason for question? I had an intermittent check engine light which
shows the oxygen sensor and code 12. Replaced o2 sensor but on test
drive check engine light came on after 10 miles for few seconds then
went off as before? Any ideas?
Thanks in advance
Dick
Thanks in advance
Dick
