Clutch padel problem??
Posted: Thu Sep 05, 2002 9:13 am
by ej22t-
Hi all, just installed the CenterForce clutch few days ago and now
the clutch pedal feel strange!!
Somehow when driving normally, the pedal goes as normal, but when
apply brake hard, the clutch pedal will go down to the floor and
won't return back the the normal height, it seems like air inside
the clutch system, but after bleeded air in 3 times, it still goes
the same! Someone told me that maybe the pressure plate problem,
what do you guys think?
Did anyone has the same problem before?
Are there anyway to adjust the hydraulic clutch system?
Ben
Posted: Thu Sep 05, 2002 10:43 am
by Z1Auto@aol.com
No adjsutment on the hydruclics, but I would look at your master and slave (slave first) and see if it is wet
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
