check engine light
Posted: Fri Sep 13, 2002 4:28 pm
Need to know how to self-check what CE code i am throwing...did the turbo, IC and HKS downpipe wrap up last night (started Wed. night), and car now has a CE light immediately when you start it....seems to run fine though.
My Chiltons book (all I ahe for a car that old!) says that when the key is in the on position, the CE light will pulse the code...and if the self diagnostic plug is still plugged in, the CE light will flicker....mine just stays solid when you put the key into the on position.
Adam
Adam
