gear ratios..
Posted: Mon Feb 03, 2003 9:44 am
by subaruracer755@cs.com
what was the final speed for the 92 legacys (non turbo)? I can get a rear diff for next to nothing. but I would like to know the final drives of the auto and 5MT, cause im not sure which the parts come from.
gear ratios..
Posted: Tue Feb 04, 2003 10:44 am
by ssspoon@aol.com
Mike my 92 turbo automatic is 3.90.
I have a feeling the non turbos were the same
Some 5MTs with LSD may have been 4.11
There is a metallic sticker on the back of the rear end that gives the ratio
It is often covered in muck so you can't tell it's there
Larry Witherspoon
gear ratios..
Posted: Tue Feb 04, 2003 11:24 am
by Josh Colombo
Pretty sure the n/a 92's MT had 4.111 gearing
gear ratios..
Posted: Tue Feb 04, 2003 10:14 pm
by Rod_
As far as i know the N/A manuals were 3.9 and the auto's were 4.111.
The turbos' rear diff was actually 3.545 but had a diff stepper in the gearbox of 1.100 to create an overall of 3.9
cheers, Rod .. in oz
gear ratios..
Posted: Tue Feb 04, 2003 10:24 pm
by Josh Colombo
Rod,
Depends on where you are.....down where you are, those are probably the correct gear ratios.
In the states, no normally aspirated mt got a 3.9 ratio. The 92-93 autos got a 3.9 ratio, but all the manuals got 4.111
gear ratios..
Posted: Tue Feb 04, 2003 10:34 pm
by Rod_
yeah, good point. weird how they did that - I should have realized that - just finished nightshift - yeah i know -lame excuse !!
cheers, rod
ps but maybe if the parts are jap import i'm pretty sure they are the same as ours...... had to throw that one in...
