Engine enamel
Posted: Wed Oct 29, 2003 7:32 pm
by THAWA
Is it okay to use this stuff on the intake manifold?
Posted: Wed Oct 29, 2003 8:45 pm
by LegacyT
Yes it is, do I sense an STi red manifold soon to be :wink: :D
Mark,
Posted: Wed Oct 29, 2003 9:10 pm
by THAWA
If this is sti red then yes you do :)
Posted: Wed Oct 29, 2003 10:07 pm
by scottzg
ewww! poor man mods!
Posted: Wed Oct 29, 2003 10:15 pm
by THAWA
Damn yes
Posted: Fri Oct 31, 2003 8:16 pm
by evolutionmovement
There's an etching primer for aluminum that you should use first so the paint doesn't flake off. I forget the name of it, but I believe there was a thread on it before if you search.
Posted: Wed Nov 19, 2003 3:27 am
by ciper
If you take the time to enamel the intake you might as well do other work while your at it. Parralel fuel mod and replacing the Knock sensor + Purge valve come to mind.
Posted: Wed Nov 19, 2003 3:32 am
look who's back :)
I just had the intake off last weekend.....the parallel fuel mod is a little more involved on our cars......mainly because the wonderful fuel adapter that they use on the scoobymods site is gone......If I would've had a second car I probably would've tried to rig something up. My reasoning was that for a n/a motor it wasn't that critical.
