fault codes 32
Posted: Sun Jun 22, 2003 12:29 am
by tiworld
4EAT gearbox when in drive will start to change up as soon as the car moves forward and stalls at junctions the only fault code found is 32 speed sensor 1 where is this ?
Posted: Sun Jun 22, 2003 2:16 am
I believe it's in the rear extension housing.
Posted: Sun Jun 22, 2003 5:47 pm
by tiworld
i have changed the sensor on the rear housing it still has the same problem !
there sensor 1 & 2 i wonder if its in the box it's self
Posted: Sun Jun 22, 2003 7:11 pm
So you've replaced the speed sensor 1 already?
I'd check the wiring coming from the sensor as well. Also I'd check the output from the sensor itself.
