Squeeling/sqeeking sound on pulling away
Posted: Wed Nov 19, 2003 5:20 pm
by allan
My 2.5 Legacy has been occasionally making a sound similar to a sliping belt when pulling away. Had the dealer look at it and they say it might be the flywheel / clutch????. Is this a known problem with these cars? It has 39,000 miles on it and I have owned since 18,000 miles. Noise has been present since I owned it. Only occurs occasionally usually if I take off reasonably fast
Posted: Wed Nov 19, 2003 5:47 pm
have you checked the belts?
I'd start there. They're easy to replace and cheap. If you still have the problem....then start looking at the more difficult and expensive stuff.
Posted: Wed Nov 19, 2003 6:18 pm
When I got my current Legacy it did that, and a little tightening up of the belts was all that was needed.
When you take off fast, you put more stress on the belts, so they're more likely to slip.
Posted: Wed Nov 19, 2003 9:39 pm
by entirelyturbo
If it's not the belts, then it's only one other thing: the water pump
