My low-beams dont work :(
Posted: Mon Nov 24, 2003 5:41 am
Hi guys,
A few weeks ago I noticed my headlights were dim at night. After inspection I noticed my low-beams were not turning on. When I turn my lights on they are the same intensity as my daytime running lights. My daytime running lights work properly, as well as my high beams.
My first thought was that maybe the low beam filament (in the bulb)was broken, so I bought a new pair of headlights. I had the same problem. Then I decided to check the fuses (should have done first), but they were fine. I then noticed there was a relay for each headlight. Since currently I own 2 1992 turbos (1-auto,1-standard,the standard is the car with no low beams) , I simply switched the relays from my automatic (the headlights are fine on the automatic). The low-beams still didn't work. So now I'm stumped, and decided to confide in the very knowledgeable members of this forum for aide.
Has anyone had or heard of this problem ?
Anyone have any suggestions or advice?
For anyone in the eastern-ontario region I am selling the automatic
Any help would be very much appreciated.
Thanks.
Thanks.
