Temperature dependent problem.
Posted: Tue Dec 23, 2003 5:42 pm
Well, the crazy a/f problem decided to rear it's ugly head this morning, although not as bad as before.
The problem went away a few days ago and the only difference that I could tell between normal and screwy readings was when the weather changed. Last night the weather warmed up to the 50 degree range, and that's when I first started to notice the varying a/f ratios. This morning we are still in the 50s and the problem is still there.
So what sensors, connections, or whatever could be affected by a 30 degree change in temps? Coolant temp? Idle air temp?
Also, can injectors overheat? I know it's a crazy question but they do have 200,000 miles on them and I'm wondering whether they could be on their way out (finally).
I'm cleanching at straws here:(
