Exhaust tempatures
Posted: Fri Jan 09, 2004 7:26 pm
by bignose
Hi,
Wondering what kind of tempature's are to be expected for the air going from the Turbo to the intercooler.
The reason i ask is i was on a scene last night [i'm a fire fighter]. It was a tipped diesel truck and we had to pump it out before writing it.
I was holding the sucker hose, and it said 150psi on it.. and it's a vacuum hose.. and it's flexable.. ;) see where i'm going ?
So if that hose stuff can take the temp's it's a perfect candidate for my saab 900 project. It's about 10$ a foot and won't collapse under suction.
just need a metal section to mig weld in a bung for the DV and i'm good to go. Sould make for a nice clean istall.
FYI, it's commonly called "Fuel delivery hose"
Posted: Fri Jan 09, 2004 7:35 pm
by ej22t
Jeff, hows going, just to say hi and we don't forget you from Toronto!!
Happy New Year to you! :D
Ben :o
Posted: Fri Jan 09, 2004 7:55 pm
I've used radiator hose... I would expect fuel delivery hose to be fine too.
As an off-hand guess I'd say temperatures shouldn't get much higher than 250-300 degrees Fahrenheit. Temperatures are high, but it's not like you're pumping solvents through it.
Posted: Fri Jan 09, 2004 8:17 pm
by bignose
thanks ben.. maybe some day i'll be back to visit..
2 to 3 hunderd degree's works out to between 90 and 140 celious which isn't all that hot.
this stuff should work perfectly.
Posted: Fri Jan 09, 2004 8:47 pm
by ciper
Share the love! Where do you purchase it and at what angle can it bend?
Couldnt it also be used for radiator/coolant hose?
Posted: Sun Jan 11, 2004 12:23 am
by bignose
hrmm, i'd say it could do a 90 with a 1 foot or less radius.. in a 2+ inch diamater hose..
for 2 inch dia. the material is about 1/4 inch think..
you can buy it as shops that specialize in heavy machinery , or hydraulics.
i'm personally very inexperienced, so i can not comment to say if it would be suitable for a radiator.
Posted: Sun Jan 11, 2004 8:50 am
by rsstiboy
sounds like it would be pretty heavy
