Putting an auto transmission in is hard.
Posted: Mon Jan 12, 2004 3:51 am
Ill leave most of the painful details out.
In order to get the two lowest studs to line up I put a long extension in the loop next to the alternator, clamped a pair of vice grips to the end and put a scissor jack between the extension and the radiator support. This held the engine at a good 20 degrees.
I had a hell of a time getting the knob in the torque converter into the center of the flex plate. Finally I pulled forward on the TC slightly and it slid out from the transmission
So I tried moving the transmission into the TC while bolted up but that was impossible. I unbolted it from the flex plate and after 3 of us messed with it for 15 minutes each we finally had to take the transmission back out
Now I got the TC back on the transmission. Thats a good job in itself because you have FOUR spots where it can get hung up! I decided I didnt want to do it a second time so I took the air sander and made the TC knob rounded on the end.
Hopefully now it will be easy to line up. I gave up on that for the time being to remove the axles from a different car for transplant.
Anyone have pointers?
