Clunking from front end on bumps
Posted: Tue Jan 13, 2004 3:36 pm
Interesting problem, been gradually getting more noticeable. When I drive over a bump (speed bumps for example, or sometimes cracks/swells in the road) and only hit the bump with one side of the car, I get a clunking noise, definately the sound of something loose and moving around.
Oddly enough, the bump ONLY occurs if ONLY one side of the car hits the bump. So if I hit a speed bump dead on, there is no noise, if I hit th speed bump one wheel at a time, then I get the clunking. It is more prominent in the passenger side, however it does occur on the drivers side as well.
I am assuming it's something sway-bar or steering related, but wondering perhaps where I should begin tighening and investigating. I've already had the sway bar links replaced, but not the mounts or the bar itself. I've checked everything visually and there is nothing that stands out, but I'm no mechanice myself.
If anyone has some suggestions of what to look at, that wouldbe really appreciated. I want my Legacy to SHUT UP!
Thanks guys,
Chris
Thanks guys,
Chris
