Page 1 of 4
LINK ECU
Posted: Fri Jan 16, 2004 12:59 pm
by rsstiboy
I'm getting a LINK ECU with 3 bar map sensor and hand controller!!
are you happy for me!?
hoping for at least 180kw@wheels and a mid-high 12 sec 1/4 mile when its finished
Posted: Fri Jan 16, 2004 8:01 pm
by georryan
Sweet Doggy! Keep us posted.
Posted: Fri Jan 16, 2004 11:31 pm
by Kelly
Dude! Your stoked!
I would think 180whp is a reasonable goal
Good luck, and happy tuning.
Posted: Fri Jan 16, 2004 11:48 pm
by boostjunkie
180kw does not equal 180hp. I dunno of the conversion factor, but it ends up being more than 180hp (especially since he expects to run mid-12s).
Posted: Sat Jan 17, 2004 12:35 am
by mTk
It comes to roughly 241whp
MK
Posted: Sat Jan 17, 2004 1:33 am
by Kelly
Oh ya, "kw"
Good luck :thumbup:
Posted: Sat Jan 17, 2004 2:42 am
by ciper
rsstiboy: Awesome! By the time you have yours tuned maybe I can ask questions to get mine running great.
With 240 wheel, how much crank would that be?
Posted: Sat Jan 17, 2004 9:03 am
by georryan
It's close to 300, since Yukon said that his dinoed STI was around 260 wheel hp. That is if I remember correctly.
Posted: Sat Jan 17, 2004 9:41 am
by MY92
All depends on what dyno is used and its configuration at the time.
Posted: Sun Jan 18, 2004 11:37 am
by rsstiboy
some of my friends think that it will be closer to 200kw @wheels which would be capable of a low 12 high 11, i'm not so confident. 147kw=200HP so i'm guessing about 270HP at the wheels is what they expect.
Posted: Sun Jan 18, 2004 5:19 pm
by jbs_racing
Just take kw * 1.36 and you get hp
Posted: Sun Jan 18, 2004 8:07 pm
by ciper
The only reason I ask is because drivetrain configuration and dyno type change the HP drastically. Its alot easier for everyone to compare theoretical CRANK Hp numbers.
I think Ill be in the mid to high 300's crank.
Posted: Sun Jan 18, 2004 8:11 pm
by MY92
You can generally guess hp roughly from turbo specs.
Posted: Sun Jan 18, 2004 8:14 pm
by ciper
Not really, who knows what other hardware the person has. He could be using the stock computer with an S-AFC and stock injectors for all we know.
I plan to keep my car automatic and with smaller than stock diameter tires so that will also change what the dyno shows.
Posted: Sun Jan 18, 2004 8:22 pm
by MY92
Of course you can.
Assuming the car has been modified wtih a good tune which can make the most of all the hardware, you limit will be the turbo.
This does come down to tuning though, which is the key ingredient I feel.
I've always gone for an aftermarket computer or chip (real time dyno tuned) as one of my first mods. I believe in very fine tuning to get power, with a safety margin put in place (you know how close you are to the edge)
Posted: Sun Jan 18, 2004 11:31 pm
by rsstiboy
car manufacturers use crank horsepower because its very difficult to prove them wrong, they can always fudge the figures a bit, thats why I always use power at the wheels, after all thats what spin the rollers, not the crank. and its far more accurate.
Posted: Mon Jan 19, 2004 10:45 pm
by ciper
I think your right. Its also funny that car makers will spec 250 at xrpm yet they make no mention of it being the PEAK HP. So the STI is 300 300 yet its peak may actually be 330 310.
Posted: Thu Jan 22, 2004 12:34 pm
by rsstiboy
getting tuned today!!
let you know how it ends up......
Posted: Thu Jan 22, 2004 7:34 pm
by ciper
You are going to get a base tune and then adjust on your own or have them tune the crap out of it for you?
Posted: Thu Jan 22, 2004 8:57 pm
by rsstiboy
I've already done the base tune they are going to make it awesome!
Posted: Fri Jan 23, 2004 2:09 am
by LaureltheQueen
I believe art's STi dynoed in at 255.6 whp
Posted: Fri Jan 23, 2004 2:15 am
by Yukonart
LaureltheQueen wrote:I believe art's STi dynoed in at 155.6 whp
That's actually 255.6 HP, darling.
If it dynoed at only 155.6 I would have taken the car back to Carter and thrown the keys at the sales manager by now.
Posted: Fri Jan 23, 2004 2:20 am
by MY92
Perhaps it was kW?
Posted: Fri Jan 23, 2004 2:21 am
by LaureltheQueen
typo. Still had it right!!!
Posted: Fri Jan 23, 2004 2:25 am
by Yukonart
LaureltheQueen wrote:typo. Still had it right!!!
Indeed. . . . you did.
