Cam choices...
Posted: Tue Feb 24, 2004 9:02 pm
by EurosportRally
Hey guys,
I am ready to finish off the motor. I have two choices of cams to use, stock EJ25 cams or twin turbo JDM cams. I have been using the legacy cams with my previous EJ20 motor, but I was wondering if there are any advantages of the EJ25 cams.
Motor has the following:
JE pistons (8.5:1 CR)
Eagle Rods
Stock forged crank
Running 18-24 psi.
Thanks,
Andrew
www.eurosportrally.com
Posted: Thu Mar 04, 2004 9:24 pm
by JasonGrahn
do you have the specs for lift and duration for each?
Posted: Thu Mar 04, 2004 11:39 pm
by evolutionmovement
Without knowing cam specs, I would GUESS at the turbo cams as the other cams are for a N/A car and would probably have more overlap. Cam specs would tell the tale for sure though.
