Taking damn PCV valve off!
boostjunkie
Post by boostjunkie »
I got a new PCV valve from Autozone yesterday. Tried undoing the old one with my 19mm closed-wrench. No dice. Anyone know how to loosen the thing up? I don't wanna screw up the manifold threads.
add more force behind it.......make sure you are doing the lefty loosy method instead of righty tighty ;)
ciper
Post by ciper »
Use a deep socket.
Vise grips.
boostjunkie
Okay, add more torque. Got it. I just wanted to make sure I wouldn't end up stripping the threads.
Time to break out the air-tools!! :twisted:
Sometimes it's easier if the manifold is warm. And sometimes it's easier if it's cold.
Sometimes it also helps to turn it very slightly clockwise first.
boostjunkie
Tried both of those suggestions already.
Oh. Then a B.F. hammer with a Craftsman box wrench?
boostjunkie
I'd rather use the air tools. They sound cooler!
createnew
Post by createnew »
Those air tools could cause some damage. If you are set on using them you should probably keep it on a low setting. I've seen wheel lugs strip comming off using those things. Good Luck
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
QuickDrive
Lurker-King
Post by QuickDrive »
boostjunkie wrote:Time to break out the air-tools!! :twisted:
I wish I could say that...
R I P-------- 91 Turbo 4EAT --------R I P
boostjunkie
They're not mine, but a friend of mine has a compressor and a set of tools to go with it. I used to hate doing installs suchs as suspensions and stuff (those damn strut bolts!!) but now, I just hook up the air gun and *snap* they're off!!
I might try a breaker bar first, just to control the torque a little bit.
970subaru
Post by 970subaru »
penetrating oil and heat almost always work for me. might be siezed though.
I love to case.
