t- bird turbos
Posted: Sun Mar 14, 2004 9:36 pm
by azn2nr
will the t-bird turbos work on our cars? are they bigger and can they push more power ?
Posted: Sun Mar 14, 2004 9:45 pm
You're talking about a turbo from a 1987-1989 Thunderbird turbo coupe, right? The Warner-Ishi/IHI one?
The turbo itself won't bolt right up, primarily because the exhaust flanges are different.
I think the turbine wheel is the same as on our cars anyway though.
The compressor wheel is larger, and it can be swapped onto our turbos if you also swap the housing.
http://bbs.legacycentral.org/viewtopic.php?t=1086
Posted: Mon Mar 15, 2004 2:11 am
by LegacyT
Ya you can swap in the compressor to make a hybrid turbo for our cars.
Mark,
