Well after an hour and a half of searching i couldnt seem to find any similar problems. It seems as though my transmission is making a loud noise. The problem is definatly worse when the car is cold. The noise is there when the clutch is out, and seems to dissapear when the clutch is depressed. I thought it was my clutch,(it was really old and slipping bad) But the noise is still there 2k after the new clutch was put in. Has anyone had this happen, and what am i looking at getting done here? I hope there is some way around a transmission rebuild, if not what is a reasonable price to pay for this?
Thanks a million
Transmission noise
Transmission noise
@The Beast@
1992 Legacy L 5MT
Exhaust, tint, fogs, anti-snorkus, plugs, wires, rims, tires, stereo and shifter knob :-)
A good car is like a good woman...
She will turn on when you want her to and she will always give you the ride of your life.
1992 Legacy L 5MT
Sounds like the throw out bearing. I always replace them with the clutch.
I have the same problem with the 92 wagon I just bought.
The fella who sold it to me said It needs a throwout bearing, but it actually seems a bit backwards to me. I think it may be the Main Bearings. I would think that if it was the throwout bearing, it would act up when the clutch is IN, not when it is out........ Does this sound wrong anyone?
I'm No Car Expert by any means...I barely have a grasp on how cars even work.
I'm going by the troubleshooting section in the front of the Haynes manual, and by the comments posted in this thread
(This thread was started by the guy I got my wagon from).
Kastrix, (If you're still around here), I'm VERY curious to know what you find out. Please update this thread if/when you figure out what is going on.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
No.
Throwout bearing noise is when the clutch is out. The clutch fork is not applying pressure to the bearing so it makes noise. Apply even light pressure to the clutch and the noise will subside.
Kastrix- did you do your own clutch? Did you replace the throwout and pilot bearings?
The other possibility and this is common in subarus is with the slave cylinder. The point where the slave pushes against the fork becomes worn and the two parts rubbing against each other makes a squeaking sound... easily mistaken for throwout bearing noise because it goes away when you put gentle pressure on the clutch.
Try to put a little grease between the slave cylinder and the clutch fork coming out of the top of the tranny and see if the noise subsides.
Kyle
Kyle
Well, I was able to get under my car while it was running today.
The noise in question (for me) is definitely coming from the "skinny end" (rear) of the Transaxle. I think if it was throwout noise, it would be coming from the "fat end" (Front). Correct?
Could it be the Pilot bearing? Or am I just grasping at straws here...
People keep telling me Throwout, but it doesn't seem to add up.
I would hate to go through the trouble of replacing the throwout for nothing.
The noise doesn't go away as soon as pressure is put on the clutch as described above, but it waits until the clutch is all the way down to go away.
What confuses me the most is why is my transmission making noise at all if the car is stationary, and out of gear? Especially confusing is that it's at the rear end of it.
What is spinning inside there when the car is running in neutral?
Ditto.ciper wrote:Sounds like something connected to the input of the transmission. When the clutch is out and the car is in neutral the shaft spins at engine speed.
Have you looked at the transmission fluid?
One of the input shaft bearings or something else internal. I would drain the fluid check the plug. It's metallic so see how much metal is floating around there.
Kyle
I see...
No, I haven't checked out the tranny fluid yet. I just picked up the car a couple days ago.
Thanks for explaining the input shaft spinning. That was confusing me.
SO, It doesn't sound likely that it's an easily replaceable Bearing or anything, eh? More like a rebuild type of thing...?
That's what drove me to replace my transmission. Main shaft bearing. Probably cheaper and quicker to replace with a lower mileage used unit.
