help! turbo seems very hesitant
Posted: Sun Mar 21, 2004 1:47 am
by Legacytuner
when im hitting around 11psi the car seems to be jerky in all gears.
I had this problem last year and replaced the oem boost controller with a pretty nice DNA racing B/C and every thing was fine through the winter for a couple months until it started to be above 20 degrees outside and it is doing it again but it is alot worse than before could it be a vacume leak? :(
Posted: Sun Mar 21, 2004 6:02 am
Jerky? Is it possible you're hitting the fuel cut? When the ECU detects sustained overboost (usually about 13 psi for more than about 3 seconds) it cuts all fuel to prevent the engine from killing itself. Does it feel like the engine suddenly stops -- like you hit a brick wall -- and then starts again when boost drops a little?
JERKEY TURBO
Posted: Sun Mar 21, 2004 4:46 pm
by Legacytuner
No i have a boost guage and it hits 11psi and its not fuel cut, i know what that feels like.
Posted: Sun Mar 21, 2004 5:29 pm
by legacy92ej22t
Things to check are fuel filter, plugs, plug wires, O2 sensor and some have said that changing their alternator has cured hesitation. I replaced my knock sensor recently and that helped a lot. Usually changing the plugs with NGK V-powers gets rid of most hesitation issues though.
Posted: Mon Mar 22, 2004 2:14 am
by Legacytuner
thanks for the info i could probably use new wires and plugs . can anyone point me to a site with performance wires for our cars?
Posted: Sun Apr 04, 2004 11:30 pm
by LegacySport4L
i agree on spark being the most likely issue. It sounds like your car is breaking up under full boost because the spark is too weak from the wires being beat up, or the spark is too aggressive because the gap has increased. Your spark plugs are probably "blown out" or "gapped out" from running extra boost over time.
Posted: Mon Apr 05, 2004 12:11 am
by evolutionmovement
Magnecor
